Old 08-16-2013, 09:01 PM   #1
engee
Drives: Subaru
First Wet Experience
Well, it finally happened. Finally did my first event in the rain. Car handled surprisingly well for what it's worth. This was not a SCCA event so I only have raw times.
FTD was 1:04.268 dry White BMW Z4M.
Mods:
22mm adjustable Whiteline front sway bar
OEM Camber bolts (-1.0 in the fronts and -1.5 in the rear with slight toe in)
Dunlop Direzza ZII 215/45 R17
I actually experimented with the different traction control settings. My fastest wet lap was with everything off. You always knew when the tires were about to lose grip. I felt VSC sport to be super invasive and I could not hold my speed or lines. Was wondering what other people's experiences were and thought this would be some good discussion. Also, any critiques to my driving is welcome too.
All off - 1:13.674
[ame]http://youtu.be/JCUA7mhoPiM[/ame]
VSC Sport on - 1:15.318
[ame]http://youtu.be/MEPEiYTrrmU[/ame]
engee is offline   Reply With Quote
Old 08-16-2013, 09:21 PM   #2
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Looked like a blast.
I agree with your comments about the trac and VCS settings. IMO it seems to do more harm than good and in some cases completely has caused me to loose focus.
I pretty much have begun to always turn everything off. I tried just turning off traction control while driving but, it always manages to come back unless VCS is off as well.
The Following User Says Thank You to Kiske For This Useful Post:
CSG Mike (08-16-2013)
Old 08-16-2013, 11:58 PM   #3
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Ive honestly had more fun in the rain on stock tires and alignment than i have had on my current tires and autox alignment on dry pavement.
supramkivtt2jz is offline   Reply With Quote
Old 08-17-2013, 12:07 AM   #4
YDNA
YDNA's Avatar
Drives: Raven FR-S
title is a bit misleading. sounds like you had fun. was it a little sticky? your tires i mean.
YDNA is offline   Reply With Quote
My Experience. Chen Northwest 2 12-29-2012 01:49 AM
For those who have experience with KW v3's deedz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 10-25-2012 09:00 PM
CEL and SL on -My experience so far bazi Issues | Warranty | Recalls / TSB 21 09-10-2012 11:13 PM
My drive experience crouchy35 AUSTRALIA 9 08-12-2012 04:39 PM
Any experience with appradio2 ? staycrushing Electronics | Audio | NAV | Infotainment 4 06-11-2012 03:14 PM
