Drives: 2013 scion FR-S
What brake rotors do you recommend?
I've been looking for new brake rotors for my FR-S and I'm debating wether or not to get slotted or drilled. Any suggestions?
Drives: old
Factory, there really is no performance benefit to slotted or drilled, and plenty of negatives to em.
Drives: 2013 6MT Asphalt FR-S
If you are going to upgrade from factory to an aftermarket rotor, definitely do slotted rather then drilled. Most of the time drilled rotors are more susceptible to developing cracks between the holes in the rotors, especially if you do not break them in properly!
Drives: 2020 BRZ tS #54
depends on what your going to be doing
Drives: 2005 Toyota Camry
If you have to ask, OE blanks.
Invest in pads and brake fluid if you are not going to seriously track the car. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | Barbarian (08-16-2013) |
| Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! | Mike@CZP | Brakes, Suspension, Chassis | 348 | 06-01-2018 12:29 PM |
| Removing rear brake rotors? | Kuzuri | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 07-18-2015 09:08 PM |
| Upgraded brake rotors for track? | ultra | Tracking / Autocross / HPDE / Drifting | 26 | 04-30-2014 10:34 PM |
| BBK,BRAKE PAD,BRAKE ROTORS,MASTER CYLINDER BRACE +MORE @ Source,LLC | SOURCE,LLC | Brakes, Suspension, Chassis | 94 | 07-07-2013 10:56 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
