Drives: 2013 BRZ Limited
W/M for N/A?
I did a search but didnt come up with anything. Is anyone running w/m on their n/a car? I've run it on my last three cars with great results but they were all F/I.
I'm partially interested because I ran it on my 2.0t FSI (VW/Audi Direct Injection) as a means of slowing carbon buildup which was a huge problem on the first gen VW/Audi direct injection motors. In conjunction with a catch-can it virtually eliminated carbon buildup. In addition, when tuning for it, even on the stock turbo, I picked up 20whp. Obviously I know the gains wouldnt be that substantial, however I'm curious what kind of gains people are seeing. |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
What is W/M?
Drives: 2013 Asphalt FR-S
water / methanol
~Namaste~ |
| The Following User Says Thank You to mad_sb For This Useful Post: | Anthony (08-14-2013) |
I don't think your going to get much response as i have not seen many if any running WMI on NA FA20's. If E85 is available, that is probably a better option. E85 tunes will gain 15 - 20 whp over pump tunes in most cases. A portion of the gains are due to the oxygen content of E85 and a portion are due to high octane and detonation resistance. I suspect you will get some gains but not as much as E85.
~Namaste~ |
#5 | |
Drives: Black 2013 FRS
It's something I've thought about a lot however I haven't pulled the trigger yet. In an N/A car you wouldn't use much water as you wont cool the incoming air as it's already the same temp as the water which you are injecting.
The Answer
Drives: Mazda 2
Don't worry about carbon buildup, this car has also port injection
