Old 08-12-2013, 11:48 PM   #1
Admired
Drives: 2013 Scion FRS
Invidia front pipe rub?
I just installed my perrin catback overpipe and invidia catless resonated front pipe however there is a obvious rubbing noise when driving and its right under where I sit. I noticed when I installed the front pipe there was like 1 mm clearance between the resonator and oil sump and i assume this is where the problem is. I did not install the bolt on the hanger and pipe may that be the problem?? Also is it bad to drive with the exhaust like this until I get it fixed? In addition my exhaust tips are at way different depths. I tried using thoose collars and loosening up on the v clamp but as soon as I get it where I want it goes back to the original spot.
Admired is offline   Reply With Quote
Old 08-13-2013, 08:44 AM   #2
Mike86
Drives: Scion frs
My catless resonated invidia front pipe fit like a charm i didnt touch the hangers or anything been almost a year with no issue!! You should def lift the car up and take a look im sure your vendor will take care of you if that is the issue!
Mike86 is offline   Reply With Quote
Old 08-13-2013, 09:25 AM   #3
Admired
How close is the resonator to the oil sump? Is it bad to drive like this until I can resolve the issue
Old 08-13-2013, 09:36 AM   #4
Mike86
Drives: Scion frs
Id have to chek to make sure i can always chek after work but i just remember looking at it when i installed it and it didnt look like there was a possibility of it rubbing ill take some pics tonigh and send them to you if you want!
Old 08-13-2013, 09:40 AM   #5
Mike86
Drives: Scion frs
I doubt you can do any harm short term but i would def chek it out cause its for sure not "normal"
Old 08-13-2013, 11:17 AM   #6
Admired
Yes that would be great I appreciate it
Old 08-13-2013, 12:07 PM   #7
xxscaxx
Drives: 2013 SWP BRZ
Why would you not reinstall the bolt for the hanger? What type of noise is it making?
Put that bolt in, and you won't have to worry about it moving and hitting anything.
xxscaxx is offline   Reply With Quote
Old 08-13-2013, 01:07 PM   #8
Admired
A obvious rubbing noise. I tried but I couldn't get the bolt in the holes didn't quite line up evn with force
Old 08-13-2013, 08:54 PM   #9
brzadmir
Drives: 13' BRZ, 05' 325xi, 02' RAV4
I had the same issue as well installing the Invidia catless front pipe, had to jam the piece of metal into place and finally got it in fitting properly.
brzadmir is offline   Reply With Quote
Old 08-13-2013, 09:25 PM   #10
Admired
Jam what piece of metal into where? The hanger and the hook thing?
Old 08-13-2013, 09:28 PM   #11
pcporo
No Martians here?
pcporo's Avatar
Drives: FR-S Asphalt MT
just installed my invidia catless front pipe yesterday and it fits perfectly
pcporo is offline   Reply With Quote
Old 08-13-2013, 10:09 PM   #12
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
I also have the Invidia catless front pipe and Perrin Catback with no issues.
Car is gone - parts for sale
6speed_Sam is offline   Reply With Quote
Old 08-13-2013, 10:16 PM   #13
brzadmir
Yeap, right there but, then i had problems where the midpipe connected to the front pipe, i was getting leaks; so i had to do it over and over till everything properly bolted up. From what i remember correctly, i took the stock rubber piece from the OEM front pipe and used that to install to connect to my aftermarket catback exhaust. After that piece, it was a lot easier to jam the piece where the hanger and the hook align and it was a lot easier to jam it into place with zero exhaust leaks so far!
FS Invidia Resonated Front Pipe jpit Engine, Exhaust, Bolt-Ons 10 08-26-2013 01:53 AM
Fs: Invidia resonated front pipe FRSex Engine, Exhaust, Bolt-Ons 0 08-04-2013 10:43 AM
invidia resonated front pipe Area51 Engine, Exhaust, Bolt-Ons 2 07-28-2013 08:07 AM
FS: Invidia Q300 & Invidia Front Pipe DR1FT Engine, Exhaust, Bolt-Ons 15 06-07-2013 07:29 PM
Invidia Catless front pipe NEW Area51 Engine, Exhaust, Bolt-Ons 1 05-21-2013 01:54 AM
