Old 08-12-2013, 08:01 AM   #1
giraffee
giraffee's Avatar
Drives: Slowly
Which would you rather? A question for the detailers
1. Leave car parked outdoors on grass, surrounded by medium sized shrubs, no large trees but susceptible to tree sap, bird poo etc
2. Purchase a good quality outdoor car cover eg: covercraft but possibly scratch the car.
Basically those are my two choices. Which is the lesser of the two evils?
I drive the car maybe 2-3x a week.
Thank you
giraffee is offline   Reply With Quote
Old 08-12-2013, 07:56 PM   #2
FnFast
Doctor
FnFast's Avatar
Drives: Fast
Anytime you can keep you car away from the elements the better.
Jeremy Clarkson "If you go though the Pearly Gates, backwards, in a fireball, that's a cool way to die!"
2013 White Pearl BRZ Limited 6MT - 15% Tint, Debadged, HIDPowerhouse LED Interiors and Dome
FnFast is offline   Reply With Quote
Old 08-12-2013, 07:59 PM   #3
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
On grass? Looks like you can put a canopy there and park your car under it.
Just my 2cents
86_ZN6 is offline   Reply With Quote
Old 08-12-2013, 10:58 PM   #4
giraffee
giraffee's Avatar
Drives: Slowly
Just my 2cents
I did that.. Then the wind snapped it yesterday, luckily car was unharmed :/
Old 08-12-2013, 11:34 PM   #5
whaap
whaap's Avatar
I would think of what the wind would do with a car cover on. How long do you think it would take for the buffeting to start showing damage to your paint finish? I envision a dry towel being rubbed back and forth on a dusty car and what that would do.
whaap is offline   Reply With Quote
Old 08-13-2013, 08:05 AM   #6
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
If you buy a quality cover, specifically fitted for your car (I have 3 Noah covers by Covercraft, purchased from AutoAnything), ensure the car is absolutely clean before installing it and use the gust-guards front and rear you can leave the car out in gale force winds with no paint damage. The Noah cover is my favorite for outside storage, soft inside and thick enough to protect from falling nuts or small branches. And they wash easily in a commercial washing machine.
I rotate three cars outside year-round and with a little extra effort before covering, have maintained a show quality finish on all three.
BTW, parking on grass will allow the moisture to permeate your chassis and undercarriage and could result in degradation where you can't easily see it. It's much worse than parking on concrete or asphalt. If possible, I would stake a quality waterproof tarp down (I've used tent stakes) in the area where you're parking, then park over it before covering the car.
Just my 2 cents on this, there are a lot of opinions. I'm basing mine on some 30 years of experience in always having more cars than garage space!
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
Old 08-13-2013, 09:30 AM   #7
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Wind + car cover = swirl marks and the removal of paint.
On my fathers A7 we had a car cover, the wind would pick up and move the cover in a little bit and now near the trunk you see slight removal of clear coat. Only i can see it but still...
I'd only use a car cover for an inside car which won't be driven often, even then you have to be positive the car is 100% clean on the body.
If your so afraid of the paint just make sure you always have a good coating of wax or sealant on the paint. Maybe go Opti coat, it wasn't for me but it might perfect for you.
Old 08-14-2013, 06:23 AM   #8
giraffee
giraffee's Avatar
Drives: Slowly
so much for your suggestions.
My car isn't clean a lot of the time, well not spotless so it seems no car cover would be the better option.
I have opti-coat already but am still cynical on how much it can protect against swirls/scratches when using a car cover.
Old 08-14-2013, 05:05 PM   #9
Clembo
Clembo's Avatar
Below is what a quality, properly fitted cover should look like - it fits snug to every body panel. If properly fitted there is no movement of the cover at all in the wind and with the addition of gust guards, it will stay in place through most anything mother nature can dish out. Almost three years like this and I have no swirls (most of them come from improper washing), no rubs, no scratches and no damage anywhere. BTW, this is on a Mazda MX-5.
Old 08-14-2013, 10:20 PM   #10
Greg Nichols
Paint Correction Guru
Greg Nichols's Avatar
Drives: F150 Platinum
to lessen the evil on the car cover, only put the cover on after the car has been washed.
How will you get tree sap with no trees around?
Cheers,
GREG
Reflections Detailing of Utah
"Detailing for the discerning owner"
Meguiars/Ford detailing team SEMA 2010 and 2011
Ask a pro blog writer for detailed image
duPont Registry approved detailer
Greg Nichols is offline   Reply With Quote
Old 08-17-2013, 07:57 AM   #11
giraffee
giraffee's Avatar
Drives: Slowly
Cheers,
GREG
Honestly, I have no idea, but it's all over my car. There are some big trees nearby (sorta)?
I have just come to the conclusion that trees like their sap spread like the plague.
Old 08-21-2013, 01:51 AM   #12
bestwheelbase
Drives: 1985 P-Type
This is big. You could build a small shelter to solve the tree sap issue, but if you park on grass or dirt, the moisture from the ground is going to ruin your undercarriage with premature corrosion. If you cannot park on pavement, definitely put down some thick plastic. Just like in the crawl space of a house.
Old 08-26-2013, 09:00 PM   #13
Mr. Sparkle
Mr. Sparkle's Avatar
Drives: Mr. Sparkle Detailing Wagon
I dont like either option, but I may go without the car cover. I've corrected a few cars specifically because of damage from car covers.
Mr. Sparkle is offline   Reply With Quote
Old 08-26-2013, 10:28 PM   #14
radroach
Drives: car
If you're on some land, you can do a try an industrial shipping container, and add a modern finish or paint to cover up the sheet metal if you need to, and just create a personal garage pod http://www.ebay.com/sch/Shipping-Con...-/92079/i.html
car cover, covercraft, outdoors, tree sap
Opti coat detailers in Sac? MyGT86 Northern California 7 09-05-2013 01:15 PM
Detailers in south florida? Danny Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 01-28-2013 06:45 PM
Detailers in GTA Minovsky Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 06-25-2012 02:53 AM
Detailers in SB to OC? Bonburner Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 06-24-2012 02:55 PM
