Old 08-10-2013, 09:43 PM   #1
Toyobaru808
Bridgestone Potenza RE760
Anyone got any experience with these?
Id grab PSSs but they're a bit over my budget since after shipping to hawaii it'll run me close to a 1000 for a set (not including mount and balance)... so I'm looking at the RE760 as an alternative.
My only concern with these RE760 (245/40r17 @ 25lbs) is that it'll put my wheel and tire combo at 44lbs per corner, will this be noticeable for DD and spirited run?
Does anyone have any other suggestions?? Im looking for a tire with good turn in response and corner stability.
Toyobaru808 is offline   Reply With Quote
Old 08-10-2013, 09:51 PM   #2
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
I have them in 215s and they are pretty good. They were on wheels I bought. Road noise isn't bad, grip is decent. My own money in that category, I'd get Hankook V12s though.
If you want serious grip though, look into Hankook RS3, but it won't last as long as RE760/V12, but will be VERY grippy.
Edit: I autocross a lot, I do everything to keep weight off of the car so believe me when I say, don't worry weight of the tires. Quality of the tire is more important than anything, a few pound difference vs a crappier compound is NEVER worth it
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 08-10-2013, 10:19 PM   #3
TRD_86
Drives: 2013 86 white
I have used 4 sets of the RE750/RE760 series many years for my Prelude. Each of this set last about 75k/80k miles w/ rotation for my DD commuting. It has good hydroplane, nice comfort, quiet road noise and decent price. You can see tirerack performance test review the 760 compare to others.
TRD_86 is offline   Reply With Quote
Old 08-10-2013, 10:28 PM   #4
Toyobaru808
I thought about the v12s but alot of review say the steering response is slow and vague, can you comment on that?
Old 08-10-2013, 11:21 PM   #5
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
i personally like bfgoodridge. Their tires are cheap, and they work well.
bkblitzed is offline   Reply With Quote
Old 08-11-2013, 10:30 PM   #6
Kido1986
Dodging cones
Kido1986's Avatar
I never found that to be the case. Knowing what they are like, I'm betting they are underinflating them. They do REALLY like high pressures. I ran them around 38-39psi cold.
Even tracked on them at the beginning of my autocrossing, until I advanced to the point where I knew I needed dedicated tires.
Old 08-12-2013, 10:08 AM   #7
troek
troek's Avatar
Drives: 2012 Toyota 86
interesting, i overheated my tires(v12) too quickly when i aired them that high. although, they are a bit too fat for my rims. they like 32-34 psi cold much better. and even at that psi they dont feel vague. the stock tires felt like a much softer sidewall.
Old 08-16-2013, 01:14 AM   #8
Carlysh
Carlysh's Avatar
Drives: 2007 Mazda 3, New Raven FR-S 6mt
Good thread I am looking for feedback on tires for me too because my route on the car for now is some driving to work and some weekend autocross unfortunately they don't do autocross on fort myers, florida i have to drive 2 hours to tampa or Miami so I have to take that in the account to that until I have seen the Dunlop z2 they have a good price on tire rack and Michelins pilot super sport any other tires you guys can recommend would appreciate I am going to run 225/45/17 front and 245/45/17 rears thanks guys
Carlysh is offline   Reply With Quote
Old 08-16-2013, 07:49 AM   #9
Kido1986
Dodging cones
Kido1986's Avatar
RE760 is comparable to tbhe PSS, but the PSS would be better all around. The Z2 is in a different class than these other two though. Z2 is heads and shoulders above these in terms of grip. However, you get a lot more road noise and a slightly stiffer ride with the Z2.
Old 08-16-2013, 08:26 AM   #10
ZDan
ZDan's Avatar
Drives: '23 BRZ
I wouldn't put the RE760 in the same class as the PSS. It's going to favor longevity a bit more than grip. The Z2 is going to give more dry grip, but less wet grip than the PSS.
Dry: Z2 > PSS > RE760
Wet: PSS > Z2 > RE760
Inundated (standing water): PSS > RE760 > Z2
You should look at other tires in the Max Perf category if PSS-like grip is desired: http://www.tirerack.com/tires/TireSe...40&diameter=17
Eagle F1 Asymmetric 2 is only $112 in 245/40-17, less than the RE760.
Old 08-17-2013, 07:30 PM   #11
Carlysh
Carlysh's Avatar
And my tires setup is good? Wouldn't hurt the car? My car is stock but my first mod will ne tires I know 225/45/17 square is a good setup but i like 245 how it looks but I have to know too if itwill help too onthe autox thanks guys
Old 08-17-2013, 07:39 PM   #12
ZDan
ZDan's Avatar
Drives: '23 BRZ
You would want 245/40-17 rears, not 45s, which are too tall.
However that would make the rears *slightly* smaller diameter than fronts, but honestly I think the issue would be more cosmetic than anything (slight "big fronts/little rears" look). You *might* consider 215/45-17 fronts with 245/40-17 rears if that worries you.
Old 08-17-2013, 09:34 PM   #13
Carlysh
Carlysh's Avatar
I don't worry I just getting suggestions for my setup you sound really good since I want to autox my car I just looking for feedback and help thanks for your opinion its helps going to tire rack now lol
Old 08-19-2013, 04:14 PM   #14
Hanakuso
I was thinking about the RE760 but it seems the S04 might be a better fit for me. They are more performance oriented and cheaper. Although less thread wear.
Hanakuso is offline   Reply With Quote
New Bridgestone RE-11A Hanakuso Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 51 02-13-2014 11:51 AM
FS: Bridgestone Potenza RE01 265/35/18 235/40/18 Migs. Wheels and Tires 10 08-01-2013 10:42 AM
Why do some FR-S cars come with Michelins, and others Bridgestone? husker741 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 53 07-13-2013 01:23 AM
Wheel Directory: Bridgestone BEO ar.S-03 18x8.0 +49 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 09-05-2012 03:51 PM
NEW Bridgestone R10 Race DOT tire RRnold Other Vehicles & General Automotive Discussions 2 06-17-2011 05:58 PM
