Old 08-10-2013, 04:08 PM   #1
mtimney
mtimney's Avatar
Drives: 2013 BRZ Limited
P&L Header installed and rockin'!
I just put a P&L header (w/cat) on my BRZ. It, combined with my Unichip, ISIS exhaust (2nd cat delete) and Perrin overpipe, was really the thing to top off my present engine mods.
I'm still working on a perfect Unichip map for this combination, but the car has a noticeable amount of extra torque down low. I had an autox this past weekend and for the first time I was working more on controlling the back end of the car than the front.
I've only done a few autox events, and in the past I've typically hit the corners too hot and fought understeer. Not this time! While I still hit some corners too fast, this time I really had to work to ease into the throttle a little more as the rear end was much easier to break out because of the extra power.
I've put the results of the top times for the top three or four cars in each class next...
mtimney is offline   Reply With Quote
Old 08-10-2013, 04:13 PM   #2
mtimney
mtimney's Avatar
LINK REPAIRED!
You can see the BRZ...even with a rookie driver...can keep up! See 'Street Touring' class.
http://www.ft86club.com/forums/album...pictureid=5784
Old 08-10-2013, 07:16 PM   #3
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Photo no work?
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 08-10-2013, 10:13 PM   #4
Clint520
Clint520's Avatar
Drives: GBS BRZ AT
Video!!
Clint520 is offline   Reply With Quote
Old 08-11-2013, 12:11 PM   #5
mtimney
mtimney's Avatar
Sorry...no video. I'm going to start doing that at my next auto-x 8/25.
Old 08-11-2013, 12:36 PM   #6
Prowl647
Drives: Brz premium
I know you have a unichip and a catted header but did you get a CEL with the install?
Prowl647 is offline   Reply With Quote
Old 08-11-2013, 05:10 PM   #7
mtimney
mtimney's Avatar
I did get a CEL with two of the maps I was using. I'm trying two more maps this weekend and am having better luck. The car's just running too rich.
Also, I've communicated with Unichip Jack and he's going to help me out if these next two maps don't work out. Great customer service from them!
Old 08-11-2013, 05:52 PM   #8
Prowl647
Drives: Brz premium
How come you didn't try an o2 spacer?
Old 08-11-2013, 09:19 PM   #9
mtimney
mtimney's Avatar
Since I have the primary cat in position, it only made sense to me to have an O2 sensor and get a reading from the engine so that the ECU and the Unichip could tell what was going on and adjust for it.
And...it's been a good thing since it's running too rich most of the time. I'm working with Unichip Jack now to get her running perfect.
Installed my PPE Engineering header Evil86 Engine, Exhaust, Transmission 47 07-16-2014 08:25 PM
SARD Japan Header & Mid-Pipe & Header & ECU nigel-jdmparts Engine, Exhaust, Transmission 63 01-21-2014 12:20 PM
Tint, lights and backup cam installed, and camber kit installed in Gainesville area? husker741 Southeast 2 08-16-2013 03:59 PM
Perrin Header Back Installed!! tonytduc Engine, Exhaust, Transmission 1 01-03-2013 10:58 PM
Anybody rockin Work Kiwami 18x8.5 +38 in the front? serial gixxer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 10-06-2012 07:59 PM
