Old 08-09-2013, 09:58 PM   #1
Admired
Drives: 2013 Scion FRS
Invidia Catless Resonated Front Pipe
Anyone have one on there FRS/BRZ? How is it compared to the regular catless?
Admired is offline   Reply With Quote
Old 08-10-2013, 12:15 AM   #2
Captain Insano
I cannot compare to regular catless frontpipe as I've only run the catless resonated... I am running the catless resonated frontpipe with an Invidia Q300 and a P&L overpipe. Between the frontpipe resonator and the midpipe resonator and the large muffler I have absolutely zero drone and it's very quiet except when I'm getting on it above 3K RPM. Even then it just sounds aggressive, but is not loud.
I think this will be a pretty good sounding combo when I get a header too. I expect there will be zero rasp.
Old 08-10-2013, 12:21 AM   #3
Owns94n
Drives: 2013 Subaru BRZ, 2013 WRX PBP
I have Q300 with Invidia Catless front-pipe and from my experience i get zero drone, and cruising around sounds normal just a little more aggressive. But when i lay on the throttle, it gives me the noise i want but not obnoxious at all. I assume with a resonator on the catless pipe it would just make it a decent bit quieter. Will still give an aggressive sound but probably not as loud as catless. Which when paired with the Q300 is really not too loud so that is why i chose regular catless over resonated catless. And the price for the catless pipe is a steal!
Owns94n is offline   Reply With Quote
Old 08-10-2013, 01:15 AM   #4
Admired
Currently I have but haven't installed the Perrin resonated catback, perrin overpipe, revworks uel header and invidia catless resonated fp and takeda intake system. I am just concerned it won't be loud enough and am considering sending back/selling my front pipe and going just catless and no resonator. What do you think about this? Can you still return products to ft86sf once you install them?
Old 08-10-2013, 01:16 AM   #5
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
We run one on our silver car. I say you should always run at least a resonated or catted front pipe. Catless = to much drone.
FT-86 SpeedFactory is offline   Reply With Quote
Old 08-11-2013, 06:53 PM   #6
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
[ame="http://www.youtube.com/watch?v=Eth_MNlFGEA"]BRZ Invidia Q300 Catless Startup - YouTube[/ame]
cant say compared to catless but with an overpipe and a q300 catback, it isnt too loud but alot louder compared to stock
andrew5826 is offline   Reply With Quote
FS Invidia Resonated Front Pipe jpit Engine, Exhaust, Bolt-Ons 10 08-26-2013 01:53 AM
Fs: Invidia resonated front pipe FRSex Engine, Exhaust, Bolt-Ons 0 08-04-2013 10:43 AM
invidia resonated front pipe Area51 Engine, Exhaust, Bolt-Ons 2 07-28-2013 08:07 AM
Invidia Catless front pipe NEW Area51 Engine, Exhaust, Bolt-Ons 1 05-21-2013 01:54 AM
New Invidia Resonated Catless Front Pipe RallySport Direct Announcements, Contests, Giveaways 8 02-04-2013 05:06 PM
