Old 08-09-2013, 04:14 PM   #1
jdmblood
jdmblood's Avatar
Drives: white subaru brz
17" vs 18"
thinking of upgrading to 18 inch rims on my brz. Other than looks what are gonna be the main differences between the two?
jdmblood is offline   Reply With Quote
Old 08-09-2013, 04:18 PM   #2
djdnz
1337
Drives: 2013 BRZ WRB S/C
Cons of 18": Weight, cost of tires, ride quality.
Pro's of 18": Less sidewall movement, looks
djdnz is offline   Reply With Quote
Old 08-09-2013, 04:24 PM   #3
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
Protip: Go on tire rack, use the tire search, and act like you are putting in to get a staggered setup for a car. Do one pair in our 215/45-17 size and one pair in an 18" size of your choice. Complete search. Observe how much more some tire models are in the 18" versions.
Don't forget to account for long term tire costs. You could potentially pay much more for a certain model in 18", or price may end up precluding you from desirable tire models you might have otherwise afforded were you shopping for 17". 215/45-17 is often a hard size to beat for value.
The Following User _________ Stay_Puft(09-13-2014)
Says Thank You to
MmmHamSandwich For
This Useful Post:
MmmHamSandwich is offline   Reply With Quote
Old 08-09-2013, 04:28 PM   #4
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Also note that a 17" wheel that weighs [say] 18 lbs. will have less rotational inertia than an 18" wheel that also weighs 18 lbs. That is because the barrel (where most of a wheel's weight is concentrated) is half an inch closer to the hub in a 17" wheel compared to an 18" wheel.
Old 08-09-2013, 04:38 PM   #5
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
There is a common misconception that an 18" wheel setup fills out the wheel well better then a 17" setup. If you keep the circumference (or height) the same to maintain the stock gearing and speedometer reading, then the outer measurements are the same.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 08-09-2013, 04:46 PM   #6
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I agree that if the circumference is the same this is true, but most people who go with 18" wheels go with 225/40/18 thru 255/40/18 tires. Even the 18" TRD wheel setup went with 225/40/18 tires.
225/40/18 has a slightly higher ride hide compared to the OEM 215/45/17 size filling in the wheelwell a little more. There are some people who choose to go with 225/35/18 (which is a tiny bit closer to stock) but that is actually lower than the stock height and will actually leave a larger gap. I think most people avoid the 35 profile tires cause ride quality will suffer even more plus the tires get even more expensive.
mit_peid is offline   Reply With Quote
Old 08-09-2013, 04:54 PM   #7
Gary in NJ
Gary in NJ's Avatar
I completely understand, but you can achieve the very same effect - even with a 17" wheel.
A 245/40-18 tire has a height of 25.7 inches. A 245/45-17 also has a height of 25.7 inches. Both tires fill the wheel well the same but the 17" has about 1/2 more sidewall height.
But the 18's weigh more (same design/model) and the tires weigh and cost more.
Old 08-09-2013, 05:26 PM   #8
jdmblood
jdmblood's Avatar
so the ride quality will decrease with sighted a?
Old 08-09-2013, 06:40 PM   #9
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
Originally Posted by jdmblood View Post
so the ride quality will decrease with 18" wheels and tires?
all other things being equal, yes.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 08-09-2013, 07:49 PM   #10
jdmblood
jdmblood's Avatar
dont understand what youre trying to tell me...
Old 08-09-2013, 07:57 PM   #11
Drofnum
Drives: CBS Subaru BRZ
Takes more to stop the 18's and more to get them spinning basically. Extremely simplified version there.
Drofnum is offline   Reply With Quote
Old 08-09-2013, 08:29 PM   #12
jdmblood
jdmblood's Avatar
so an 18 inch wheel would be slower?
Old 08-09-2013, 08:45 PM   #13
tonyfrs86
tonyfrs86's Avatar
Drives: 2013 raven frs
i would only go 18" if you're using a turbo, like myself..i need a bigger/wider tire. i break traction pretty easy with nitto motivo's when i romp on them..in the wet taking a turn, have to keep it steady or back end comes out.
if you're not pushing alot of power and want steering response and all then then stick with 17" but looks and power got 18"
tonyfrs86 is offline   Reply With Quote
Old 08-09-2013, 09:01 PM   #14
jdmblood
jdmblood's Avatar
I'm planning on doing intake exhaust headers and tune. Dont plan on dropping the car. What do you guys think?
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
