#1 | |
Site Moderator
Drives: Supra
2013 Scion FR-S: Track Tested
New Supercharger, New Attitude
![]() Quote:
Drives: 2003 Camry Blue | 2013 FR-S White
i'm wondering if this bolt on is carb legal? Since the one with the tune is carb eo pending.
If it is, I might jump on the ball with this one and put back my OEM filter. Though I hope they can have a pipe that uses the TRD-USA filter , that would be nicer for me. |
Can't help but think how much better it would have been with a FI kit putting down 250-300 whp.
Also they copied the handling numbers wrong from their last test.
2022 BRZ Build 2013 FR-S Build |
I was thinking the same thing. The numbers are an improvement but not as drastic as I was expecting. It sounds like the tires being worn definitely affected some of the launch times, as I was expecting sub 6 sec 0-60 w/rollout.
Drives: '08 328i, '13 Accord Sport, '13 BRZ
Wait wut? am I reading this right?
6.5 to 6.3, 0-60 with a supercharger?? that doesn't sound right. If it's, then adding that supercharger is definitely not worth it. This is disappointing, I was hoping to have a close to 5 secs 0-60 FRS with a supercharger and basic mods. I hope I'm reading this wrong. |
Drives: 2013 Firestorm FR-S
guys, they didn't launch the car from 6,000rpm (it was less than 3,000) like most mags and STILL got a ~6.0 0-60 with three shifts and worn tires. The 3rd shift alone is 1/2 a sec and launch RPM also makes a difference.
Their original ~6.5 0-60 involved a ~6,000 rpm clutch dump. under more optimal conditions (with a tune and higher rev limiter) with better tires and a more aggressive launch your at a ~5 sec 0-60 time.
2013 Firestorm FR-S, MTX, build date 1/13.
#7 | ||
Edmunds is normally more conservative with their launches in general than say Car and Driver or Road and Track. While they may have found with the worn tires that was the best RPM to launch at, I'm sure a good driver with fresh tires could launch the car at a higher RPM and get a better time.
Think of this as a worse case scenario with a car that can't hit 60 in two shifts. Correct a couple of these issues and you have a easy low 5 sec car.
Drives: Mazda 3
the important thing is 0-75 is 8.7 vs 9.6 This is also with the worn out AD08s vs fresh AD08s. the most interesting test which they didn't do is the 5-55 and 30-70 acceleration test...
#10 |
4g63>rotards
Drives: 98'GSX 11'Tundra 10'Wrangler
ehrmurgerd 14's!!!!
#11 | |
Drives: Moped
#12 | |
Typically Edmunds is about .5 seconds conservative with their numbers. But I have seen them off everyone else by 1.5 seconds before which makes no sense. Sometimes I wonder if they are truly disabling traction control. I remember with their Genesis Coupe review awhile back it was pretty obvious they were not. |
#13 |
Drives: 2013 Firestorm FRS
wow...massively disappointing. Based on the innovate car I've been in, and other peoples innovate posts, I feel their(edmunds) numbers are a bit...slow
#14 |
Drives: E92
What about on a 6AT car? I don't think it requires 3rd gear to 100km.
2013 Scion FR-S 6AT
| Borla cat-back w/ UEL header tested at the track | BeltedBiscuit | Engine, Exhaust, Transmission | 17 | 12-30-2012 03:57 AM |
| FR-S makes list to be tested for 2013 Canadian Car of the Year Award | jenzan | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 10-19-2012 07:59 PM |
| Track Test: Edmunds 2013 Scion FR-S with Upgraded Wheels and Tires Pulls 1.0g! | poormans_LFA | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 09-08-2012 01:46 AM |
| Element Tuning Track Tested and Track Proven FRS Video | Element Tuning | Tracking / Autocross / HPDE / Drifting | 47 | 07-17-2012 05:12 PM |
