Old 08-07-2013, 05:31 AM   #1
tn08
Wheels and tires for turbo help
I just ordered and full blown turbo kit and plan on running around 300 hp when all is said and done. I really like the TSW Nurburing wheels and was needing some help on a tire selection and width that would be grippy enough for the extra power and not break the bank. So i'm not all day everyday.
tn08 is offline   Reply With Quote
Old 08-07-2013, 06:05 AM   #2
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
How wide do you want your rims ?
Do you want to fully hook up even In first or don't mind a bit of wheel spin, if you won't be drag racing I strongly recommend michlen pilot super sports, not the cheapest but best over all tires for some big power
Old 08-07-2013, 08:06 AM   #3
MooKz
MooKz's Avatar
Drives: 2013 Scion FR-S Firestorm Red
I also purchased my Ptuning turbo kit and will be in the same power range and I don't wish to stay on the stockers.. I was thinking 17x8 or 17x9 wrapped in 245/40R17 all around so I'm also interested in this topic
Sent from my HTC One using Tapatalk 2
MooKz is offline   Reply With Quote
Old 08-07-2013, 08:10 PM   #4
tn08
I want them to be flush with the fender. I wont be doing many drags at the track but still want some grip out of the hole if I need it
Old 08-08-2013, 02:50 PM   #5
MooKz
MooKz's Avatar
Any suggestions on this one? I'm doing searches online but I'm not sure which wheel sites to go with...
Old 08-08-2013, 03:05 PM   #6
mike the snake
IMO it depends on whether you will be performance driving (track days or AX), if you Are, then 18x8.5 with 245 square would probably be your best bet, giving good out of the hole traction and the best track handling.
If you are going for a street setup, then staggered definitely looks better IMO, I'm running 18x8.5 front, 18x9.5 rear, 45 offset both front and rear, with MPSS 245/35/18 front and 265/18/35 rears with coilovers and a 1.5" drop and it looks outstanding IMO and will give great street performance. I plan to use my old stock wheels with some sticky rubber if I decide to track or AX, so I wanted to lower the car and stuff as much rubber inside the fenderwells as i could for great looks. I will be getting a trubo kit in the next few months, and I believe that my wheel/tire combo will do just fine.
The Following User Says Thank You to mike the snake For This Useful Post:
ZionsWrath (08-08-2013)
Old 08-08-2013, 03:12 PM   #7
ModBargains.com
ModBargains.com's Avatar
TSW's don't come in a wide fitment to really put down a big tire. The widest they make in 5x100 would be 8" Wide which I'd be ok fitting a 245 on but that's maxing the tire out on the width of that wheel.
What you really need is a 9.5 on the back with a 265 to get the meatiest tire on the ground to put down the power, that will be just fine with 300HP. I've got a large selection of wheels that fits your needs checkout either of these threads to see what options we have:
▀▄▀▄▀▄▀▄▀▄▀▄▀ - ******MODBARGAINS ULTIMATE WHEEL GUIDE****** - ▀▄▀▄▀▄▀▄▀▄▀▄▀
ModBargains.com | Forgestar Wheels for your BRZ/FRS - Rotary Forged/Customize Yours!!
That should help out big time!
ModBargains.com is offline   Reply With Quote
Old 08-08-2013, 03:16 PM   #8
MooKz
MooKz's Avatar
Looks like I'll be going with Klutch SL14's 18x8.5 with 245/40R18 all around
Old 08-08-2013, 08:05 PM   #9
KONVERTER
KONVERTER's Avatar
Just have 0 camber in the rear so you get every bit of tire on the ground.
Once you start running any negative camber you only get half the rubber on the ground so doesnt matter so much how wide you go.
Then again, the more weight you add the less you have to worry about your wheels breaking free anyway...
KONVERTER is offline   Reply With Quote
Old 08-08-2013, 08:07 PM   #10
ZionsWrath
Thanks
ZionsWrath's Avatar
you have more pics of your car? I have same wheels, thinking to go with same exact tires too but want to make sure it looks the way I want. I got 255 rear DWS right now and it looks stretched and making the lips of my wheels chip and i hate it lol.
link me more pics plzzz
Old 08-08-2013, 08:40 PM   #11
mike the snake
Here's a couple more crappy pics. I'll take some more and post them. Hopefully you can see how the 265's fit on the rim, basically flush or maybe a tiny bit of tire protruding past the rim lip edge. I was told the Michelin PSS tires run big for their size, so 265's are more like 275's from other brands.
On my car the 265's are a tight fit. I had to grind down the fender tabs and they seem to now not rub except for the very biggest dips or potholes, or getting Kattywompuss when 45'ing it out or into driveway or parking lot entrances.
Old 08-08-2013, 09:14 PM   #12
MooKz
MooKz's Avatar
I'm not quite sure how 255 all around would look.. Maybe even too much meat?? But I was thinking 245s on 17s so I guess with 18s I should be fine.. Have you guys ever worked with www.wheelfire.com
Excuse my giddiness... I'm soon to be Boosted!
Old 08-08-2013, 09:43 PM   #13
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
I'm running 255/35/18 tires on 9 inch wheels square on Dunlop Direzza ZIIs
I have way more grip than the current engine can utilize.
I'd think 9 or 9.5 inch wheels would bu suitable with 300hp
More pics here: http://s1291.photobucket.com/user/Tr...20by%20TrogDor
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
Old 10-26-2013, 03:25 PM   #14
slowmo
slowmo's Avatar
Drives: '13 BRZ
I'm running 9.5 wide wheels on 400whp and facing issues with traction in 2nd and 3rd
400+whp
slowmo is offline   Reply With Quote
FS Momo Tuner Wheels 5x100 W/ KDW Tires (Rare Wheels) kanundrum Wheels and Tires 19 10-11-2013 09:26 AM
SOLD CreinCrein Canada Classifieds 4 08-25-2013 11:26 PM
Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! stratodyne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2013 02:21 PM
WTB: OEM 16" wheels/tires or similar 16" skinny alloy wheels (USA, CA) smmmurf Wheels and Tires 0 04-05-2013 12:42 PM
17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? SteveH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-14-2013 10:26 PM
