Old 08-01-2013, 12:03 AM   #1
Toyobaru808
245/45r vs 245/40 on a 17x9
Are there any advantages to running a 245/40 over a 245/45?
Im specifically looking at Continental extreme contact DW
This would be for my DD and occasional spirited drive
Toyobaru808 is offline   Reply With Quote
Old 08-01-2013, 12:37 AM   #2
cdo221
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
One advantage is that 245/40s are significantly closer to the OEM tire/wheel overall diameter than the 245/45s.
If your speedo says 75 and you're on 245/45/17s, you're going to actually be going 78 mph but with 245/40/17s, you'll actually be going 75 if the speedo says 75.
cdo221 is offline   Reply With Quote
Old 08-01-2013, 12:46 AM   #3
Toyobaru808
Huh, yeah youre right....
I thought that since our stock tire has a sidewall of 45 that getting a 245/45 would the same.. weird. why would increased width affect diameter??
Old 08-01-2013, 12:53 AM   #4
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
245 is the width of the tread in millimeters
45 means the sidewall height is 45% of the tread width.
Stock tire: 215 * 0.45 = 97MM
Tire 1: 245 * 0.45 = 110MM
Tire 2: 245 * 0.40 = 98MM <-- Winner! Winner!
So the 245/40 is closer to the oem sidewall tire.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 08-01-2013, 01:03 AM   #5
Toyobaru808
AHH i see, i always thought the sidewall number was a fixed measurement like mm or something like that.
Thanks for clearing that up
Old 08-01-2013, 01:29 AM   #6
cdo221
I was thinking about this in the shower just now too..
Generally speaking, the lower profile the tire (shorter the sidewall), the stiffer it will be. It translates into better handling/acceleration/braking usually - so aside from the speedometer accuracy, the 245/40/17s should have a performance benefit over the 245/45/17s as well. The downside is of course decreased ride-quality going over pot holes/bumps due to the stiffer ride.
Old 08-01-2013, 04:49 AM   #7
Felix
Drives: Toyota 86 GTS
What are people's thoughts on 17/40/255's?
Compared to 245's?
I'm thinking about going 255's and a little worried about clearance issues... It'll be dropped fairly low on coilovers
Felix is offline   Reply With Quote
Old 08-01-2013, 04:51 AM   #8
ft_sjo
Drives: GT86
40's will have less compliance than 45's.
40's (of the same tyre) will have less ride comfort.
40's will have less grip over typical roads.
40's may provide better suspension/arch clearance.
So the bottom line; if the 45 clears the suspension/arches, then it's the better tyre.
Old 08-01-2013, 08:50 AM   #9
djdnz
1337
Drives: 2013 BRZ WRB S/C
Compared to 245's?
Wheel specs? 255 on a 9" is not a prob, just offset matters
djdnz is offline   Reply With Quote
Old 08-01-2013, 08:57 AM   #10
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
I'm running 18x9 wheels with 255/35 ZIIs ... no issues with rubbing. I'm running RCE Tarmac 2 coilovers as well with a 1.5" drop ...
I would think a 17x9 +40 would be fine if you dropped an inch ...
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
Old 08-01-2013, 01:28 PM   #11
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
technically anything lower than a 235 you would want a 45 or more sidewall. Anything more than a 245 tire and you would want a 40 or less sidewall.
bkblitzed is offline   Reply With Quote
Old 08-01-2013, 07:10 PM   #12
Felix
RPF1's 17x9 +35
17/40/255's all round.
Lowered on coilovers so there is no wheel gap (hopefully), maybe a little tuck if possible
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
Xxr 531 17x9 +35 Drftfan Wheels and Tires 14 07-28-2013 10:19 AM
Should I try a 17x9 +20 square? Drftfan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 07-21-2013 05:40 PM
Wheel Directory: XXR 531 17x9.0 +35 Drftfan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 07-19-2013 05:16 PM
