Old 07-30-2013, 02:01 AM   #1
pitstops
Drives: SC RB FRS
EPIC Frs Rocket Bunny Build!!
Just wanted to share my build with you guys.
stay tuned, ill be adding more and more parts soon...
ill be adding pics to this post, newer pics on top, older ones on the bottom..see the progress.
10 best cars of 86fest!
http://www.superstreetonline.com/eve..._at_86fest_ii/
Nisei showoff!!
aeromotions carbon wing mounted!
Volk te37v
17x9 -20 offset
17x10 -30 offset
quick mockup, looks good
ark performance dts exhaust, looks badas
Picked up some sti brembo brakes from Airway auto parts in sun valley, ca. 08+ is direct bolt on, and previous years need a bracket. i got the bracket from knsbrakes.com i just called them and told them what my setup was and they sent me the correct adapters.
As for brake pads ill be using the cl rc6 i have from my evo. pads are interchangeable.
DBA T2 Rotors, got the front rotors for 04 sti, rear rotors for 08 sti. Rotors are drilled for both 5x100 and 5x114
thermo graphic heat paint
Had these laying around. Its brake ducts from a porsche gt3. Goes over the control arms, its ziptied but does the job, 20 track days and no problems on my evo.
went with the eibach multi-pro coilovers, paired with swift springs.
another item left over from my evo, agp catch can. nice little can has a 3 chamber system. used a rubber damper i had from a old intake system and mounted that to the intake manifold tab.
pitstops is offline
Old 07-30-2013, 09:30 AM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Yay another SoCal sponsored build. :yawn:
King Tut is offline
Old 07-30-2013, 12:30 PM   #3
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
I like
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline
Old 07-30-2013, 12:51 PM   #4
xDBOYx
xDBOYx's Avatar
Drives: 2013 SWP BRZ Limited
Pics of rocket bunny?
xDBOYx is offline
Old 07-30-2013, 03:07 PM   #5
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
-20/30 offsets
those clear those huge brembos?
DuMa is offline
Old 07-30-2013, 03:18 PM   #6
ModBargains.com
ModBargains.com's Avatar
Subscribed!
ModBargains.com is offline
Old 07-30-2013, 03:42 PM   #7
SigmaHyperion
Originally Posted by DuMa View Post
-20/30 offsets
Looks like they barely clear the stock calipers based on the mounted photo.
It'll be a TIGHT fit if it clears those Brembos at all.
SigmaHyperion is offline
Old 07-30-2013, 03:52 PM   #8
GuerillaRacing
GuerillaRacing's Avatar
Drives: Scion FR-S
Loving the wheels!
GuerillaRacing is offline
Old 07-30-2013, 03:59 PM   #9
pitstops
Drives: SC RB FRS
-20/30 offsets
it fits!
i have a finger gap from the caliper to the spokes
pitstops is offline
Old 07-30-2013, 04:40 PM   #10
RIPTRD71
RIPTRD71's Avatar
Drives: Raven FR-S 6MT
shits sick man!
Originally Posted by wootwoot View Post
She's stiff as a goose. I tried yanking out the motor too, that was pretty stiff as well. So.. i'll try the flux capacitor next.
RIPTRD71 is offline
Old 07-30-2013, 04:43 PM   #11
Conn
Conn's Avatar
Drives: g37
AwesomeSubscribed!
Conn is offline
Old 07-30-2013, 05:07 PM   #12
KAR
Drives: Whiteout 6spd
How big of a spacer??
KAR is offline
Old 08-01-2013, 01:05 PM   #13
pitstops
Drives: SC RB FRS
got the wing mounted, came with the new style endplates.
install was easy, just had to drill 4 holes.
pitstops is offline
Old 08-02-2013, 06:42 PM   #14
reggie@circuitsoul
reggie@circuitsoul's Avatar
Drives: 2013 Rocket Bunny FRS
interested to see how this build goes !!
reggie@circuitsoul is offline
*ROCKET BUNNY Battleship Grey Full Wrapped Project Build* deedz Member's Car Journals 164 01-10-2016 02:19 PM
Goomba's Rocket bunny FRS build Goomba_james Member's Car Journals 106 06-22-2014 11:02 AM
Supercharged Rocket Bunny Widebody Conversion Build Thread RWDRIFT Member's Car Journals 278 01-06-2014 12:12 AM
2JZ Rocket Bunny Drift 86 build (Dubai) - action shots ultra FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 01-30-2013 04:55 AM
2JZ Rocket Bunny Drift 86 build (Dubai) ultra FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 43 11-15-2012 04:17 PM
