Old 07-27-2013, 10:00 PM   #1
RenaissanceBoy
Drives: 13 Subaru BRZ CBS Premium 6MT
Help! Removed Tom's taillights, replaced with stock, now my lights won't work!
So I removed the LED flasher that I installed when I got Tom's Taillights, and replaced it with the original flasher that I had removed before. Then I went and physically changed the taillights out. Then, when I went to check everything, the taillights work, as well as the reverse lights, but the headlights won't come on. Also the turn signals don't work. Now when I went to pull the key out and figure out what was going on, the parking lights won't turn off, and the gauge cluster is showing the high beam light, but nothin is on. I didn't mess with anything else, and everything has worked perfectly up to now, so I'm really unsure about what I've managed to mess up. Thanks for your time and any advice at all is welcomed.
RenaissanceBoy is offline   Reply With Quote
Old 07-27-2013, 10:11 PM   #2
BRZ-OwnzJo0
BRZ-OwnzJo0's Avatar
Drives: 2016 WRX Limited
Sounds like your old "flash module" is busto. Did you try reinstalling the LED flasher to see what happens then?
BRZ-OwnzJo0 is offline   Reply With Quote
Old 07-27-2013, 10:16 PM   #3
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
Check your fuses.
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
Old 07-27-2013, 10:24 PM   #4
RenaissanceBoy
Angry
Ya I put the led flasher back in, same thing happened. I also tried checking fuses but as far as I can see none of them are tripped. With that being said, I had a heck of a time trying to figure out which fuses might be linked to all the different lights. I unhooked and reattached the battery, and then tried turning it on again, same problem reappears.
Old 07-27-2013, 11:41 PM   #5
BRZ-OwnzJo0
It's almost definitely a fuse. Unless you just exploded your whole lighting system. :P
Old 07-28-2013, 03:34 AM   #6
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
dont just check, reseat the fuse. Also take one of the same type from some place else that is not needed to function (power windows?) and swap real quick. That will tell you if it is the fuse.
Old 07-28-2013, 08:59 AM   #7
BRZNutt
BRZNutt's Avatar
Drives: 2014 DGM Subaru Impreza 2.0i 5 Door
Did you re-pin your tail light connectors back to stock?
2016 World Rally Blue Subaru WRX Limited
2013 Satin White Pearl Subaru BRZ Limited 6 MT (Sold)
BRZNutt is offline   Reply With Quote
Old 07-29-2013, 10:43 AM   #8
Scoobidude
Drives: DGM BRZ
^^ agreed
Scoobidude is offline   Reply With Quote
SOCAL INSTALL AND SELL-- HID KITS--LED LIGHTS--REVERSE LIGHT--PAINT TAILLIGHTS!! F-T Exterior Parts - Lighting 202 03-21-2016 02:02 PM
WTB: Stock Taillights GT86drifter Exterior Parts (Aero, Lighting, Etc.) 0 04-14-2013 07:02 PM
FS: Stock OEM taillights P5yk0t1c Exterior Parts (Aero, Lighting, Etc.) 0 03-26-2013 01:12 AM
Has anyone replaced the stock muffler with a smaller one? ScionFrsFan Engine, Exhaust, Transmission 2 02-13-2013 07:55 PM
