Old 07-21-2013, 06:27 PM   #1
Jonoraven93
Jonoraven93's Avatar
Drives: Fr-s
Ok information please on stock rims...
If I stuck with my stock rims for now due to not wanting to spend the money for new ones, should I just get new tires for a more aggressive look? If so if I even can what size heigh etc should I get.
Jonoraven93 is offline   Reply With Quote
Old 07-21-2013, 07:58 PM   #2
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
I don't see the point in getting some aggressive tires for use the look.
If you want to look agressive getting rims would solve that faster than getting tires.
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 07-21-2013, 08:15 PM   #3
DAEMANO
Time Traveller
To look more agressive on stockers, get more low. Preferrably 1.4" low (Eibach Sportlines or CG springs). Then, get more wide (20mm spacer in front, 30mm spacer in rear). - Disclaimer - I plan to do this very thing while waiting for more aggressive wheels/tires.
Old 07-21-2013, 09:24 PM   #4
Yamajee
Yamajee's Avatar
Drives: Rocket Bunny'd GT86
Couldn't agree more plus I think the tires are gonna cost the same for a set of rotas?
Yamajee is offline   Reply With Quote
The Following User Says Thank You to Yamajee For This Useful Post:
Mr.Jay (07-21-2013)
Old 07-21-2013, 09:28 PM   #5
GT86drifter
Drift Specialist
GT86drifter's Avatar
Drives: 180SX,GT86
buy my wheels lol
GT86drifter is offline   Reply With Quote
Old 07-22-2013, 09:54 AM   #6
Jonoraven93
Drives: Fr-s
How much do you think it would be for some good tires? I'm new to this whole car modification thing really, I drove a 81 Chevy s10 for the longest time on racing slicks. The frs is my first actual car. Can someone give me some comparisons?
Old 07-22-2013, 09:59 AM   #7
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Michelin Supersports
The tire size this car should have come with is 225/45x17. Rolling circumference will be a bit larger, speedo will under read a tad but since they are designed to over read to begin with this actually works out. The actual calculated decrease in speedo reading is 1.3% and the normal speedo error is 3-5% over read.
Clearances for wider wheels and tires are significant as this car is designed for aggressive modification right out the door, heck, the rear shock towers even have holes to permit easy adjustment of coilover shocks should you fit those.
Bear in mind that fitting any better tires will pretty much eliminate the tail step out unless you really overdo a corner and get spooked into lifting off too suddenly (or do so on purpose of course).
Suberman is offline   Reply With Quote
Old 07-22-2013, 10:13 AM   #8
pche
Guy on internet
Drives: Slowly
Getting tires on stock rims make sense if you want the car to drive and perform better. Getting tires for just looks along isn't very cost effective. With that said I've seen people run up to 245/40 17s on their stock 7" rims. That made the control quite sloppy in my opinion. I would suggest 235 at the most for 7" wheels. Set of 235 Star Specs would make a big difference in grip and handling, looks, not so much.
pche is offline   Reply With Quote
The Following User Says Thank You to pche For This Useful Post:
Mr.Jay (07-22-2013)
Old 07-22-2013, 10:21 AM   #9
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
225/45/17s made my car look much more aggressive. it filled out the fenders more
supramkivtt2jz is offline   Reply With Quote
Old 07-22-2013, 12:15 PM   #10
Jonoraven93
Drives: Fr-s
Thank you guys for the info, never do I think about just kiddin the car for "just looks" I always have performance in consideration, I'm just trying to fill the wheel gap in better as I'm waiting to have the money for coiliovers. I just need examples of wat people are running on stock rims. Wider tires seem appealing to me but yet a tad bit higher as well. I know there's room for them but how does it affect a dd? As well as a fun time.
Old 07-22-2013, 12:31 PM   #11
DAEMANO
Time Traveller
Hate to say it but "a tad bit higher" would be "just for looks" because it would actually make your car a tad bit slower. Also depending on how tall your sidewalls become your steering feel could also be negatively affected (slower response, etc).
Your best bet to fill the gap inexpensively, that would actually improve performance would be to buy shorter springs (RCE Yellows, Eibachs, CGs, Tein, etc) for about $150-$250 est. Then resell them when you're ready for coils. You could probably re-sell them for $100-$150 depending on the model.
The Following User Says Thank You to DAEMANO For This Useful Post:
Mr.Jay (07-22-2013)
Old 07-22-2013, 12:47 PM   #12
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
you are trying to make up the gap in tire size which will affect the car way more and be more costly then using the stock tires and getting springs like the above suggested
Out of the FRS game
The Following User Says Thank You to Mr.Jay For This Useful Post:
DAEMANO (07-22-2013)
Old 07-22-2013, 03:36 PM   #13
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
IMO get springs and spacers. Spacers will push the wheels out for a more aggressive look
dori. is offline   Reply With Quote
The Following User Says Thank You to dori. For This Useful Post:
djdnz (07-22-2013)
Old 07-22-2013, 04:29 PM   #14
djdnz
1337
Drives: 2013 BRZ WRB S/C
Exactly what I was about to say. Spacers will make the wheels more flush with the fenders, hence more aggressive looking.
Lowering 1" will also add to that.
djdnz is offline   Reply With Quote
fs stock frs rims hunter3232792 Wheels and Tires 1 06-25-2013 12:31 PM
Stock WRX rims? ashtray Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 04-25-2013 09:05 PM
Looking for a set of stock rims Riqah Great Lakes 2 04-01-2013 08:58 PM
Stock FR-S RIMS ONLY itsibarra Wheels and Tires 2 02-19-2013 02:56 AM
