Old 07-17-2013, 09:45 AM   #1
FRiSson
Drives: FR-S MT
Anyone had their shift knob replaced under warranty?
My OEM shift knob is pretty loose. I can't tighten it more because the center spindle pushes the cap off. Thread lock compound isn't working. Anyone gotten a warranty replacement?
FRiSson is offline   Reply With Quote
Old 07-17-2013, 10:32 AM   #2
coastertrav
Drives: Whiteout FRS
Take it in
coastertrav is offline   Reply With Quote
Old 07-17-2013, 10:44 AM   #3
whaap
whaap's Avatar
If you've tried blue Loctite (don't use red) and it doesn't work, take it in as a warranty problem.
whaap is offline   Reply With Quote
Old 07-17-2013, 11:57 AM   #4
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
I had the same problem, but I rotated the knob a bit and it came down. It doesn't bother me the stitching doesn't line up, and I was going to replace it with an aftermarket piece anyway.
Chimpo is offline   Reply With Quote
Old 07-17-2013, 01:50 PM   #5
hushypushy
ビーアールゼット
hushypushy's Avatar
Drives: WRB BRZ '18
I had the same issue...I switched the stock knob out when I put it back on, I tightened it too much and the top popped off!
If I loosen the shift knob so the top fits, the knob is too loose and moves when I shift. If I tighten the knob, the top doesn't fully clip in, and sits loosely on top like this:
so...I just grabbed a pair of snips and cut the end off. Now the top doesn't clip into the knob, it just sits on top. Then I used a dab of super glue to stick it together.
Now my knob is tight and the lid fits. Total cost: $0
hushypushy is offline   Reply With Quote
Old 07-17-2013, 02:08 PM   #6
whaap
whaap's Avatar
Something else to consider is that some people driving a manual, that haven't had a lot of experience, might tend to grip the knob when shifting and this will cause it to move around. Try learning to not grip the knob. Instead, push it forward with the heel of your hand and when pulling it towards you, just use your fingers to pull it without grasping the knob. It might sound simple but the one time I found my knob really twisted out of shape was after a tech road tested my car for the rattle coming from the package shelf. It was obvious he was a 'gripper'. That was several weeks ago. I straightened it out and haven't had to adjust it since.
Old 07-18-2013, 06:14 AM   #7
grodenglaive
Drives: asphalt FR-S
I have the same issue. I loosened the knob the first time I tried to get into reverse. Dealer didn't tell me about the reverse lock out - took me awhile to figure it out. Anyway, when I tightened the knob back down, the button popped up a bit. Thanks for the fix instructions.
grodenglaive is offline   Reply With Quote
Old 07-20-2013, 11:27 PM   #8
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
I have had my knob replaced as a "one time courtesy" by the dealer. It still didn't correct the issue, they've had to apply Toyota approved adhesive. The issue was corrected for a few months, and now it's back.
crazyfrenchbiker is offline   Reply With Quote
Old 11-03-2013, 09:04 PM   #9
FRiSson
Drives: FR-S MT
Idiot dealer (Acton Toyota of Littleton). Unwanted rotation of the shift knob "Is normal".
Old 11-03-2013, 11:13 PM   #10
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
teflon tape maybe?
Old 11-03-2013, 11:48 PM   #11
Poodles
Drives: 2015 Series.Blue
Originally Posted by boredom.is.me View Post
teflon tape maybe?
This. Loctite is meant to hold tightened fasteners together, it doesn't make a loose fitting tighter. Teflon tape will tighten it up (don't be afraid to use quite a few layers as the tape is very thin)
Old 11-03-2013, 11:57 PM   #12
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Yeah, the ol' throttle-knob/gas pedal delete mod is really popular in several areas of the Andromeda Galaxy, and therefore normal. Shame on you for wasting those good peoples' time.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 11-04-2013, 07:46 AM   #13
Mikem53
Drives: FR-S 6MT
Lol... Not surprising..
Mikem53 is offline   Reply With Quote
Old 11-04-2013, 08:57 AM   #14
USMC
USMC's Avatar
Drives: 2013 Scion FR-s
I just installed a DIF Black Pawn shift knob. Feels and looks great.
USMC is offline   Reply With Quote
Anyone have a windshield replaced under warranty? NickFRS Issues | Warranty | Recalls / TSB 8 05-16-2013 10:19 AM
WTB: OEM FR-S MT Shift Knob ecko04 Interior Parts (Incl. Lighting) 0 03-22-2013 04:45 PM
TRD Shift Knob NG86 AUSTRALIA 21 12-13-2012 06:30 PM
any other shift knob? oso_25 Cosmetic Modification (Interior/Exterior/Lighting) 2 07-31-2012 01:38 AM
