Old 07-16-2013, 11:56 AM   #1
BlackyRose
Drives: 2013 Raven FR-S
TRD and K and N same filter??
As title says....
Any truth to this?
I am sure someone on here has seen and tested both
BlackyRose is offline   Reply With Quote
Old 07-16-2013, 05:15 PM   #2
KKaWing
KKaWing's Avatar
Drives: Nissan Versa
more like aFe... if you search a bit on aFe's site, you can actually find "gold" recharge kits along with filters that have the same colour scheme as TRD filters.
KKaWing is offline   Reply With Quote
Old 07-16-2013, 05:18 PM   #3
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
I'm sure if you look on the boxes, it'll say where each one is manufactured. If its the same, my bet is that they are the same. I wouldn't really be surprised.
Trashed675 is offline   Reply With Quote
Old 07-16-2013, 06:45 PM   #4
BlackyRose
Interested to find out more on this.....
Old 07-16-2013, 06:50 PM   #5
kALMIGHTY
Drives: TRD Ultramarine '13
I don't know how similar they are really. K&N filters are oiled to the max whereas the TRD filters aren't oiled as heavily, very minimally in fact.
I don't know if they're made at the same place, but they've probably got as much in common as any two random filters you could pick.
Sent from my SGH-I747 using Tapatalk 4 Beta
Old 07-16-2013, 07:11 PM   #6
BlackyRose
Interesting......hmmmm
Old 07-16-2013, 07:28 PM   #7
KKaWing
KKaWing's Avatar
More "proof"... using the Toyota Echo as an example.
TRD Part Number: PTR05-52040-11
amazon.com/dp/B0041RZLES
aFe Part Number: 30-10105
http://afepower.com/shop/details_new...ily&brandID=59
Look familiar?
Last edited by KKaWing; 07-16-2013 at 07:40 PM. Reason: Fixed dead link-ish... copy & paste -_-;
Old 07-16-2013, 07:31 PM   #8
BlackyRose
[quote=KKaWing;1074450]More "proof"... using the Toyota Echo as an example.
[ame="http://www.amazon.com/dp/B0041RZLES"]Amazon.com: TRD PTR05-52040-11 Air Filter: Automotive[/ame]
That's crazy!!!
Does anybody know exactly what filter the injen Sri uses? I want to get a new filter Frsexxxy Engine, Exhaust, Transmission 13 02-19-2013 10:04 AM
K@N Filter Junaid P AFRICA 34 01-15-2013 01:00 PM
Which Air Filter Will You Use? GhostofAkina Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 11-16-2012 09:29 AM
oil filter??? whitefrs Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 09-06-2012 07:43 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
