Old 07-14-2013, 09:27 PM   #1
charged86
charged86's Avatar
DIY Changing vortech super charger pulleys on the car
Here's how I changed my vortech supercharger pulley while unit was still attach to car. Not using a impact gun stay tuned... making dinner and uploading pictures NOTE I AM NOT RESPONSIBLE FOR ANY DAMAGE TO VEHICLE, VORTECH BLOWER OR OTHER WISE EXTRA TUNING IS REQUIRED TO USE A SMALLER PULLEY
Tools needed
14mm wrench x2 one needs to be the bendy self ratcheting
10mm 1/4 inch socket
flat head screw driver
propane torch the hand held kind
BLUE I repeat BLUE locktite
oil filter removal pliers ( yes that sounds crazy)
Oh and a smaller vortech supercharger pulley in this case my 3.125"
and a tune you need a tune!! don't go bolt this on and "just see how it feels" on the stock pulley programing!
1) remove belt cover on ac condessor (driver side)
2)completely remove top charge pipe.
3)remove grey plastic cover on back of blower pulley with a flathead. (try not to damage black washer)
3) now ready to begin pulley swap
please let me know if I screwed something up in the DIY
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 07-14-2013, 09:28 PM   #2
charged86
charged86's Avatar
^3.125in top pulley 3.48 stock bottom
^3.125in left 3.48right
^note oil filter pliers have duct tape covering the teeth of the pliers
^arm torch on medium output (the purpose of heating the bolt is to melt the blue locktite vortech installed it with)
^apply torch to bolt and side shaft of pulley for 15 seconds Note DO NOT BURN YOUR BELT!!!!!!!!!!!
^grip pulley with pliers over belt with medium grip strength
^ place 14mm wrench on pulley nut and push towards driver side!!
Old 07-14-2013, 09:29 PM   #3
charged86
charged86's Avatar
^ bolt half seated. Note leave belt on unitil bolt is completely out then remove belt with 14mm wrench on the tensionor
Go back to vortech instructions if you forgot how.
^ note orientation of special washer on bolt. and the black washer that holds void warranty plastic cover over belt.
^ turn pulley till the "keyway""woodruff key" is facing up.. slide of pulley
^do not mess with the "keyway" "woodruff key"
^grab blue locktite
^apply to pulley bolt.
slide on new pulley take your time should slide on do not force you could jazz up the key way and then you screwed
Slowly and gingerly thread bolt in the blower shaft just hold the pulley
With bare hand do not attempt to put on belt untill bolt is almost fully seated
Old 07-14-2013, 09:30 PM   #4
OrbitalEllipses
Drives: Attitude
Photos of dinner too plz.
Old 07-14-2013, 10:11 PM   #5
charged86
charged86's Avatar
Filet mignon.
Old 07-14-2013, 11:19 PM   #6
charged86
charged86's Avatar
Install belt on pulley
Hold belt over pulley with pliers tighten down bolt to 25-30ftlbs per vortech.
Make 110% sure belt is fully seated around entire pulley assemblies
Reassembly belt covers and boost pipe
Note that you will have more room towards the new pulley to adjust orientation of boost pipe so it
Does not contact idler pulley
enjoy and please contact your local tuner! DO NOT REDLINE VEHICLE UNTIL TUNING IS COMPLETED
Old 07-15-2013, 12:32 AM   #7
Dezoris
Dezoris's Avatar
Thanks man!
Old 07-17-2013, 01:38 PM   #8
accelerated
Drives: Scion FR-S
How much more boost are you seeing with the new 3.125" pulley and for reference, what was it at the same RPM with the 3.48"?
Take care
accelerated is offline   Reply With Quote
Old 07-17-2013, 04:17 PM   #9
charged86
charged86's Avatar
Take care
Dynosty just told me manifold is reading 10 on the 3.125. I'm ordering the 2.87 right now
Old 07-18-2013, 07:52 AM   #10
accelerated
Drives: Scion FR-S
So if 15 is target boost, the SC pulley is gonna have to be pretty small, eh? Have to start taking belt slip into consideration at that point.
Old 07-18-2013, 09:16 AM   #11
charged86
charged86's Avatar
The smallest pulley available is a 2.62. The next pulley up is the 2.87. I will be the third person in the US maybe the world with this pulley and it is about 12-12.5 psi. 15 psi dosent seem possible. You have to go to a 95.5in belt when you go to 2.87. If you want 15psi go turbo. And honestly I wouldn't shop forced induction kits by psi
Old 07-18-2013, 09:36 AM   #12
accelerated
Drives: Scion FR-S
Not shopping it on boost, just know that based off what I'm reading here and on the other forums, where I want to be power-wise is gonna be about 15lbs with the V3. I have one on the way and as I'm doing the install, I'll try to come up with some improvements in the plumbing department and see if I can come up with an 8-rib solution to circumvent some of the belt slip introduced with smaller pulleys. I'm coming from the euro import world and after stuffing 55AMG V8 Kompressor motors in Crossfires, 65 V12 BiTurbos in Es and doing full on drag builds with 996s, I got bored and am looking forward to getting more into the twisties and not just doing the mash and go. That's why I went with the SC vs turbo and why I picked up one of these vs going with another Benz or a Crossfire.
For kicks though, here is one of the V8 cars I built at PBIR a month ago after I went down there for a full trans build.
[ame]http://youtu.be/T4m2mzC3gv8[/ame]
Take care
Old 07-18-2013, 09:59 PM   #13
charged86
charged86's Avatar
Go for it buddy!
Old 07-18-2013, 11:19 PM   #14
accelerated
Drives: Scion FR-S
Thanks! Love that there are very passionate people on here. Also, your custom paint is amazing!!!
Vortech idler pulleys seizing and belts breaking cb7tuner Forced Induction 168 06-02-2016 03:51 AM
Vortech super charger first drive jdzumwalt Forced Induction 49 03-12-2013 08:10 AM
Turbo or Super Charger Ryan86 AFRICA 7 11-21-2012 08:14 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
