Old 07-10-2013, 12:40 AM   #1
swift996
swift996's Avatar
Nevermind - Delete
I flashed my ECU with EcuTek and I got a CEL with a code (U0122 - Network). Does anyone know what that means? Can I clear it without messing something up?
I got the code via the Torque app.
Update - I cleared the codes via the EcuTek software and am all good now. Please delete, I don't think this is worth sharing.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 04-28-2016, 04:53 PM   #2
Riftur
Riftur's Avatar
I just did my first tune using OFT 3 days ago. Everything seemed fine but I decided to check codes and I had a u0100 and u0122 through the torque app (no CEL ever came on or anything other warning light). I am using a bluetooth adapter for the torque app. I tried clearing the codes but they come right back. Once I got home from work and hooked up my OFT it did not find any codes. i switched back to the bluetooth adapter and torque and it found the codes again but OFT does not see them still. I dont understand whats going on. I never had an issue until I did my first tune. Torque never found any code ever. Any idea?
Riftur is offline   Reply With Quote
Old 04-28-2016, 05:41 PM   #3
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
are you plugging in an OBD device while the car is running?
Did you bend some of the pins in your connector?
Both may (not reliably) cause the code.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following User Says Thank You to Spartarus For This Useful Post:
Riftur (04-28-2016)
Old 04-28-2016, 05:44 PM   #4
Riftur
Riftur's Avatar
The Bluetooth device gets plugged in before the car gets turned on. Everything else in torque seems to work fine. All the real time diag etc
Old 04-28-2016, 05:49 PM   #5
Spartarus
...Just add nauseum
Spartarus's Avatar
Eh... Dunno then. Take a good look at the connector..
If the OFT isn't reading those codes when it's plugged in, ill give you 99% probability that the bluetooth dongle is causing the issue.
I threw those codes a while back when plugging/unplugging my OFT, so yes, the OFT can read them. It's not missing them, they're just not there when OFT is plugged in.
-Spartarus
The Following 2 Users Say Thank You to Spartarus For This Useful Post:
Riftur (04-28-2016), Tectoniic (04-28-2016)
Old 04-28-2016, 06:04 PM   #6
Riftur
Riftur's Avatar
I am assuming it must be the bluetooth adapter. Only thing that makes sense. I just wish it didn't happen right after my first tune. Making me totally paranoid.
Old 04-29-2016, 08:21 AM   #7
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
My bluetooth only throws the code if I have fast pin enabled.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
I won the FT-86 II Social Network Racer Competion + free trip to car's unveiling! :D Leeky Scion FR-S / Toyota 86 GT86 General Forum 76 11-27-2011 09:51 PM
Social Network Racer ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 10 10-22-2011 07:47 PM
Playstation Network OldSkoolToys Off-Topic Lounge [WARNING: NO POLITICS] 9 06-10-2011 12:16 AM
Sony Comes Clean: PlayStation Network Hackers have Stolen Personal Data ichitaka05 Off-Topic Lounge [WARNING: NO POLITICS] 11 04-27-2011 03:53 PM
