Old 07-04-2013, 04:38 PM   #1
Moto-P
Moto-P's Avatar
Drives: Many types of cars in R&D.
More fog lamp ideas on Club4AG FR-S, PIAA LP530 RFT-LED from Yamaha Tenere
With a bit of fabrication, making my own custom bracketing, and digging through wires in the car with bumper removed.We were able to fit this Reverse Firing Technology LED fog-lamps on the auxiliary lamp compartment of the Scion FRS front bumper.
The lamps themselves, we looked to motorcycle world and found that the PIAA LP530 RFT-LED for a Yamaha Tenere Cross Trek Motorcycle had nearly the right diameter for a neat fitment.
Keep in mind that this particular fog lamp assembly will require custom fabrication to fit in the FRS lamp mount, as these are not bolt-on lamps for the FRS.
Using Subaru BRZ Limited LHD turn signal stalk, we enabled automatic headlamps as well as the factory fog lamp switch without using any additional relays for the foglamps (since the LED does not draw much current in LED form, we simply tapped into the factory fog light pin unused on the Scion FR-S at the turn signal socket)
The proper pins for this is as follows:
Both sides, on the front bumper Turn Signal Connector, there should be 4 pins, one of which is not used on the Scion FRS.
On the right side, this is a white/red stripe on the main harness side, and red/ white stripe on the left side.
Tap those to the positive 12V pin of the LED foglamps
Ground the other negative pin of the fog lamp on the bare metal of the frame.
With the fog lamp relays enabled with the factory turn stalk from a Limited BRZ, everything else should simply be ready to go.
Since the PIAA LP530 RFT-LED is a non-replaceable 6000K long-life LED Array panel, the housing is watertight and semi-permanently sealed.
Ideally also these housings do not generate the high heat typical to halogen lamps, and therefore should keep the soft plastic sections of the bumper and trim from warping over time.
#PIAA #FRS86 #SOCALFRS #Club4ag #ScionFRS #86Fest
more photos here:
http://club4ag.com/piaa-lp530-rft-le...et-technology/
6/30/2013
Moto Miwa
R&D Driving Engineer, Product Designs
Consulting for Cusco, OEM+, RS-R, Toyota Japan, and Unplugged Performance.
Moto-P is offline   Reply With Quote
Old 07-04-2013, 05:00 PM   #2
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I hate/love your brilliance. I mostly love it.
The fog lights look brilliant. I am thinking of going LED with mine simply for the colour match characteristics to my HID's
PIAA Mirror Orange T20 Wedge Bulbs WY21W ryuusei Exterior Parts (Aero, Lighting, Etc.) 5 06-25-2013 09:53 PM
PIAA Super Rozza MonoBlock JoeBoxer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 11-29-2012 04:00 PM
09 Yamaha R6s gmanculb Cars for Sale/Trade 0 10-15-2012 01:23 PM
Wheel Directory: PIAA Eco Premium S-12 17x7.0 +42 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-27-2012 03:06 PM
The Yamaha Difference Exage Engine, Exhaust, Transmission 36 12-05-2011 01:03 PM
