Curious cat.
Drives: 86 GT base M/T - Red
Brake Judder
Did a trackday last weekend and now my pads are squealing. I also have a whole lot of judder coming back through the brake pedal.
Am currently running stock calipers and rotors with Ferodo DS2500 pads, stainless steel lines and high temp fluid. The car never ran out of brakes on the track (no pad or fluid fade). It's possible that the pads may have glazed over (need to check). Rotors are worn but seem to be in good condition (no cracks, heat spots or pitting and the pad material transfer looks pretty uniform to me). Main issue is how to solve this sudden judderiness. Am planning on swapping in fresh pads and fluid shortly but unsure what to do about the rotors. Can they be fixed (re bedded or resurfaced)? Would replacing them with fresh OEM rotors make sense? Would an upgrade to, say, DBA 4000 series slotted rotors improve performance and make financial sense? Or if not, BBK? Curious to hear some suggestions.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold) 1991 Mazda MX5 Miata (sold) 2007 Mitsubishi Evo 9 RS (sold) 2006 VW Golf R32 (sold) |
That Guy
Drives: 2013 asphalt FRS MT
I you didn't run out of brakes I'd stick with what works. I'm not sure what you mean by judder, if its what I think it is, you probably have a runout issue with the rotors. I'd replace them.
When you make your final stop of a session, let the car roll to a stop to preven the pads from being in contact with the rotors. This stops the pads from leaving an uneven tansfer layer which is likely the cause of the runout. |
| Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! | Mike@CZP | Brakes, Suspension, Chassis | 348 | 06-01-2018 12:29 PM |
| BBK,BRAKE PAD,BRAKE ROTORS,MASTER CYLINDER BRACE +MORE @ Source,LLC | SOURCE,LLC | Brakes, Suspension, Chassis | 94 | 07-07-2013 10:56 PM |
| FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot | CamryDS | Interior Parts (Incl. Lighting) | 0 | 06-24-2013 11:26 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
| Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 10:28 AM |
