Old 06-28-2013, 07:41 PM   #1
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
Folks with the TRD spoiler...
...how does yours fit?
I installed one this week, and I'm not totally knocked out by the fit. There's no way to get all the surfaces flush; if I have the top properly positioned, the lower corners by the tailights are just slightly (1/16" or less) 'lifted'. If I push those flush, the top corners lift. It doesn't seem to conform perfectly to the trunk contour.
It's not all that big a deal, worst case is a little water gets underneath, and I'm sure that was gonna happen anyway. And it's not noticeable unless you're looking for it (especially since my car is black). Just wondered if "they're all that way".
Admiral Ballsy is offline   Reply With Quote
Old 06-28-2013, 10:02 PM   #2
NIKDENG
Drives: RED BRZ
Do you have the original TRD spoiler or a replica? The originals fit perfectly and comes with a rubber gasket to prevent water from getting through. The replicas are hit or miss propositions on the other hand. I used to have a replica which just did not want to fit flush and kept peeling off especially after a rain and dry cycle. I got rid of them and went with the original instead.
NIKDENG is offline   Reply With Quote
Old 06-29-2013, 12:09 AM   #3
Admiral Ballsy
Shorter of breath
Original
Old 06-29-2013, 07:39 AM   #4
Panman
Panman's Avatar
Drives: 86 GTS
Original on mine
I cut the original bolts off and fitted with tape and the original rubber stripping fits perfectly. Looks great with the factory aero kit (Nur Spec) replacing the big wing.
Panman is offline   Reply With Quote
Old 06-29-2013, 10:27 AM   #5
xxscaxx
Drives: 2013 SWP BRZ
Same here. Fits perfect, and I cut out the mounting bolts and just used double sided tape that was provided.
xxscaxx is offline   Reply With Quote
Old 07-29-2013, 11:51 AM   #6
speedy racer
Drives: 92 lexus sc300 > whiteout MT FRS
So no drilling is required?
speedy racer is offline   Reply With Quote
Old 07-29-2013, 11:57 AM   #7
Admiral Ballsy
Shorter of breath
Required, not really. It has two bolts; they're located on the centerline of the two innermost holes in the decklid (if you have the factory spoiler), but are about an inch further outside. The intention is, you drill those holes and use the nylon pushnuts supplied. I did this.
But the bolts are molded into attachment points that are themselves attached to the spoiler with adhesive. So technically, the thing is 100% adhesive-mounted - and you could remove the bolts and just use tape. However there's no way to get adhesive in the area where the bolts are, so you'd not have that part of the thing supported if you don't drill.
Old 07-29-2013, 11:58 AM   #8
OrbitalEllipses
Drives: Attitude
Mine fits *perfectly* so I don't know what's up with yours.
Two holes. Takes about 5 seconds.
Old 07-29-2013, 01:20 PM   #9
ozne99
Drives: GBS BRZ Limited
After you've taken an hour to convince yourself that those holes are correctly marked!
ozne99 is offline   Reply With Quote
Old 07-30-2013, 07:36 PM   #10
Admiral Ballsy
Shorter of breath
Don't know. I've had it on four or five times, I've been able to line it up fine (took a while to figure out), but after a day or so the left lower edge pulls away from the lid a little. Always the same.
I've given up; will be selling it.
Old 07-30-2013, 07:51 PM   #11
OrbitalEllipses
Drives: Attitude
License plate edge? I'll take a look at mine.
Old 07-30-2013, 07:55 PM   #12
Admiral Ballsy
Shorter of breath
Not exactly - over the driver side taillamp. The 'corner' at the extreme left bottom.
There's probably 1/16" gap between the gasket edge and the trunk lid. I can push it back and it will stay, but the next day it's back out.
I originally thought it was compromised adhesive, or maybe I wasn't getting the pad up on the horizontal surface positioned sufficiently forward...but I've remounted it so many times, now I just figure either it or my lid is 'off'.
Old 07-31-2013, 09:03 AM   #13
stefmiesterb
stefmiesterb's Avatar
Drives: B8 A5
Price?
stefmiesterb is offline   Reply With Quote
Old 07-31-2013, 12:26 PM   #14
CrazyWookiee
Drives: Whiteout FR-S
Mine fits fine. I'm extra picky about this stuff, and haven't had an issue. I routinely go check and pull on it to make sure its secure and flush.
"I'm the real Peter Lau" - Peter Lau
CrazyWookiee is offline   Reply With Quote
Tallahassee Folks b_massey02 Southeast 21 03-31-2014 01:36 PM
Odd question for you folks... Crackseed Hawaii 2 02-12-2013 12:43 PM
Hope folks in PDX are ok Freeman Northwest 3 12-12-2012 12:16 AM
RT* folks at Nats des Tracking / Autocross / HPDE / Drifting 33 09-10-2012 07:07 PM
Where did all the old folks go? S2KtoFT86 Off-Topic Lounge [WARNING: NO POLITICS] 36 11-04-2010 12:52 AM
