What would cause this?
Heard a noise coming what seemed to be from the driver's side front of the car. I pulled the wheel and noticed all the studs have play in the hub. Is this normal? The other side is not like this. The bolts on the back of the hub are all tight.
Here is a video of what I am trying to describe. [ame]http://youtu.be/ru93cbKTPS0[/ame] Last edited by TRev; 06-27-2013 at 09:07 PM. |
Drives: Silver FRS
possible bad wheel bearing?
edit: nvm u said the studs
Drives: slow
is that not just the rotor being a bit loose, the brake keeping the rotor from moving and the studs hitting the rotor with the little bit of play that's there?
The Answer
Drives: Mazda 2
That's just the rotor's freeplay.
| The Following User Says Thank You to Rayme For This Useful Post: | TRev (06-27-2013) |
Would it possibly cause the noise I am hearing? Or would the wheel snug up the free play when tightened down? If that is not the noise, then I need to keep looking.
#6 | |
The Answer
Drives: Mazda 2
What's the frequency of the noise you hear? And what does it sound like?
Frequency is bumps as well moving the wheel back and forth quickly. Sounds like a light clunking noise. I will check out the ball joint and appreciate the help.
One of my friends is a mechanic and pretty sure we got it figured out. I have Whiteline adjustable end links and the jam nut on the bottom came loose. Thought I checked that because I recently lengthened them but must have overlooked it. I learned something about the hub/rotor and appreciate the suggestions.
#9 | |
Drives: slow
Troubleshooting should always start with the areas you've recently changed or touched. Parts recently replaced etc. So many times on my old 240 I'd replaced a part and had a weird issue and convinced myself that it couldn't be the new part because it was new. More times than I care to admit it was either a faulty new part or I forgot to tighten something up all the way. |
| The Following User Says Thank You to topazsparrow For This Useful Post: | Rayme (06-28-2013) |
#10 |
