Old 06-26-2013, 05:19 PM   #1
Turbo Den
Drives: FRS, IS300, 911sc
225/45/15 vs 255/40/17
I am in STX.
I am facing a tough fight in my club's autox. Please help.
driving my wife's automatic FRS. I have Tein H-tech & Koni, rear control arm, front camber bolt. intake & cat-less front pipe. I don't want to spend more money on suspension or engine parts.
All else remains the same, how would you feel about:
255/40/17 vs 225/45/15 ???
BFG Rivals.
23" vs 25" diameter for better acceleration to compensate for longer gear ratio in automatic.
but 8.5" vs 9.5" treadwidth kinda counter-intuitive.
Turbo Den is offline   Reply With Quote
Old 06-26-2013, 09:42 PM   #2
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
top speed in 2nd with the 225/45-15?
celica73 is offline   Reply With Quote
Old 06-26-2013, 09:59 PM   #3
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
I have thought about doing this also, I just didn't want to invest in custom 15x9 wheels to find out.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 06-27-2013, 01:17 AM   #4
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Front sway bar?
Old 06-27-2013, 08:18 AM   #5
mla163
Overthinking it
Drives: BRZ in CS
255/40/17 is too big. You'll lose acceleration
225/45/15 is too small. Like 10% less circumference. You may top out 2nd gear at 50 mph or so. It may work on a slow course. Even if it does, you may have brake fitment issues.
mla163 is offline   Reply With Quote
Old 06-28-2013, 05:51 PM   #6
Turbo Den
with 255/40/17 ... accelerate earlier without spinning the rear.
at 225/45/15... accelerate faster, but probably later to avoid spinning the rear.
i have a 22mm whiteline front sway bar, softest setting.
Old 06-28-2013, 06:08 PM   #7
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
I run a auto in stx as well. I have been through 4 sets of race tires since last year. I ran two sets of 225/45/17 last year. Not enough tire.
This year I ran at the start of the year toyo r1rs in a 245/35/17 these were amazing and I may get them next year. They helped acceleration a ton. You still hit 60 in 2nd and its only 23 pounds. My 245/40/17 rs3s are also great. But weigh more.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 06-28-2013, 06:25 PM   #8
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
Did the OP mean 225/45/17?
GTM_Challenge is offline   Reply With Quote
Old 06-30-2013, 04:53 PM   #9
Turbo Den
Nope. 225/45/15 is correct. 15". We know 15" wheels will fit. Just a matter of tire size dilemma.
