Old 06-21-2013, 08:19 PM   #1
ivanyoro
Drives: Subaru Brz
Thumbs up Is 18x9.5 +30 front,18x10 +30 rear good??
hi guys!!! i need your expertise for a stanced and perfect,cambered fitment..Do you think 18x9.5 +30 front, 18x10 +30 rear a perfect and a stanced fitment? i would be glad if you have suggestions and your expertise as well..but i liked it camberd and wide..THANKS IN ADVANCE
ivanyoro is offline   Reply With Quote
Old 06-21-2013, 08:52 PM   #2
fatoni
if it is performance you are after, no. if its a look, looks are subjective. good luck with either.
Old 06-21-2013, 10:22 PM   #3
PradiG
Drives: Fr-s
The perfect stance is subjective. The sizes you posted are aggressive and you might need to do fender work depending on how low / how much camber you want to run
PradiG is offline   Reply With Quote
Old 06-22-2013, 09:45 AM   #4
ivanyoro
Drives: Subaru Brz
yes i agree!!! thanks PradiG!!! and Fatoni!.. i really want a aggressive stance. and a fat wide look like the latest car scene today.. and specially low as well
Old 06-22-2013, 11:18 AM   #5
stancypants
stancypants's Avatar
Drives: FR-s
You will need a roll and need to run a good bit of camber but it will look good if done right with the right set of wheels
stancypants is offline   Reply With Quote
Old 06-23-2013, 12:17 PM   #6
Mild2Wild
Drives: Firestorm FR-S
Judging by the fitment on my 18x9 +35 you should be fine with even about -2 camber in the front. Maybe a little less in the rear. Lots if room left for me and you will only poke out about another 11mm.
Mild2Wild is offline   Reply With Quote
Old 06-23-2013, 07:11 PM   #7
ivanyoro
Drives: Subaru Brz
wow!!! thanks bro..ill be getting work meisters s1 18x9.5+30f,and 18x10+30 rear is this a good fitment? for a stance scene?
work vs-xx 18x9.5 +7 front with 215/40 18x10 +13 rear with 225/40 5x100 subyracer05 Wheels and Tires 66 08-07-2013 12:05 PM
18x9.5 +45 (square) VS 18x9.5 +35 Front 18x8.5 +40 Rear (staggered) Funky Fresh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 05-07-2013 09:52 AM
anyone running 18x9 front and 18x10 rear? YDNA Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 05-06-2013 12:55 AM
Miro 368's, 18x8 front, 18x10 rear HuntingtonFRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 11-19-2012 04:22 PM
17x9 +35 front .... 18x9.5 +38 rear kinryu Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-30-2012 02:19 AM
