Old 06-20-2013, 07:59 PM   #1
ML
ML's Avatar
Drives: 13 White MT FR-S
White-out post-wash
Washed the car, and snapped some pics .
The Following User Says Thank You to ML For This Useful Post:
marky (06-21-2013)
Old 06-21-2013, 01:28 PM   #2
OrangeJuleas
OrangeJuleas's Avatar
Looking clean dude. Did you plastidip the rear bumper part that the emblem goes on?
OrangeJuleas is offline   Reply With Quote
The Following User Says Thank You to OrangeJuleas For This Useful Post:
ML (06-21-2013)
Old 06-21-2013, 01:43 PM   #3
ML
ML's Avatar
Thank you. Yup, good ol Plastidip. I want to replace all the plastidip with gloss black vinyl eventually.
Old 06-21-2013, 01:46 PM   #4
oofie
Looks good!
Is the emblem still there or did you take it out? If you did, what did you use to cover up the holes?
oofie is offline   Reply With Quote
The Following User Says Thank You to oofie For This Useful Post:
ML (06-21-2013)
Old 06-21-2013, 02:00 PM   #5
ML
ML's Avatar
I took the emblem off, and the holes where small enough I put tape on the back side of the plastic and used drywall putty to fill the holes. With the layer of plastidip on it, it has worked flawlessly.
oofie (06-21-2013)
Old 06-21-2013, 02:13 PM   #6
marky
marky's Avatar
Drives: 2020 BRZ tS #54
Did you clay bar? Going to do that tomorrow on mine
Did you lower it a bit or its just the grass making it look like its low a bit
Old 06-21-2013, 02:42 PM   #7
ML
ML's Avatar
It's dropped on mach V springs. No clay, just soap and water
Old 06-21-2013, 02:48 PM   #8
marky
marky's Avatar
Yeah that's what I'm going to do.. Its like a inch drop?
Also I'm going to dip mine like this... The metallic gray one..looks like the stock rim color and I like it not really digging the silver strip.. They should of made it just one tone not a 2 tone color [ame="https://www.youtube.com/watch?v=cPVeeEzFQt8&feature=youtube_gdata_player"]True Metallic Plasti Dip - Aluminum, Anthracite & Vintage Gold - YouTube[/ame]
Old 06-21-2013, 03:56 PM   #9
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Needs a 15mm spacer in the rear an 10mm in the front, but other than that it looks great.
post_break is offline   Reply With Quote
Old 06-21-2013, 03:59 PM   #10
ML
ML's Avatar
Replacing rims ASAP
Old 06-21-2013, 04:39 PM   #11
Diode Dynamics
Diode Dynamics's Avatar
I've heard the gloss black vinyl wrap shows every single bubble, dimple and imperfection.
Car looks great IMO! gotta love the W/O color
Old 06-21-2013, 05:14 PM   #12
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
mow your grass.
supramkivtt2jz is offline   Reply With Quote
The Following User Says Thank You to supramkivtt2jz For This Useful Post:
Juvenile (06-21-2013)
Old 06-21-2013, 05:39 PM   #13
ML
ML's Avatar
No
How often do you wash your car itisthumper Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 41 07-01-2013 09:17 AM
Can you recommend a hand wash car wash in Las Vegas whaap Southwest 3 05-14-2013 06:55 PM
xxr530 black chrom on white out frs or white brz Mrqb22 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-11-2013 09:04 PM
How often do you wash your FR-S? terrypm Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 50 07-14-2012 03:24 AM
