Old 06-19-2013, 12:09 AM   #1
topazsparrow
Drives: slow
Idle sounds like a tractor
I've heard this engine can be noisy at times, but after the initial warm up of the engine when it quiets down it sounds really rattly, like a tractor.
Revs up fine and otherwise drives great, but it sounds like an old tractor when it's idling. I'll try and get a video up but I was wondering if anyone else gets this at all?
topazsparrow is offline   Reply With Quote
Old 06-19-2013, 12:12 AM   #2
mashal
DADA
mashal's Avatar
Drives: 2013
Normal. Get an exhaust so it's rumbles like a true boxer should
mashal is offline   Reply With Quote
Old 06-19-2013, 12:15 AM   #3
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
Is there a different sound when your clutch is engaged? I feel like the trans is loud when in neutral, but when disengaged, the motor is smooth as butter.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 06-19-2013, 08:06 AM   #4
xjohnx
Grip>Slip
xjohnx's Avatar
You'll need an unequal length header for that, no axleback or catback exhaust will give you an authentic boxer rumble.
Old 06-19-2013, 08:10 AM   #5
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
I believe it to be normal too. Anyone know what causes this? Its similar to lifter tick but only starts when the engine warms up
supramkivtt2jz is offline   Reply With Quote
Old 06-19-2013, 09:18 AM   #6
topazsparrow
Drives: slow
EXACTLY!
Good to know its not just me. It definitely sounds like lifters or a thrashy valve train. It's fine if you rev it up though and it's not present on initial starting of the car.
Old 06-19-2013, 09:42 AM   #7
Superhatch
AIM4APX
Superhatch's Avatar
Allow myself to quote....myself.
Do this check when at idle and see if the sound goes away.
Old 06-19-2013, 09:44 AM   #8
mid_life_crisis
Drives: FR-S 10 #103 AT
Direct injectors handle a lot of pressure. They make a noticeable ticking sound when in use. Could it be that?
Old 06-19-2013, 10:00 AM   #9
topazsparrow
Drives: slow
Didn't make a difference for me.
It's worth noting that lugging the engine in second gear (below 2k rpm) often sounds terrible and very rattly.
Sway Bar Popping Sounds? fareastbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 03-28-2020 12:23 AM
Sounds like air is coming through my doors... ThaBigUnit Scion FR-S / Toyota 86 GT86 General Forum 4 11-24-2012 01:43 PM
it sounds good! pr086 Scion FR-S / Toyota 86 GT86 General Forum 6 08-09-2012 04:46 PM
Cool BRZ/FRS/86 Car Sounds! dookie11 BRZ First-Gen (2012+) — General Topics 0 06-12-2012 01:13 PM
Exhaust sounds?! koyv90 Engine, Exhaust, Transmission 12 04-08-2012 12:24 PM
