Old 06-09-2013, 08:14 PM   #1
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Whiteline KSR210
Anyone able to tell me what KSR210 would help with?
Also will it require work to have the old ones pressed out?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 06-09-2013, 09:42 PM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
It helps with turn-in and feedback. The old ones do need to be pressed out, but they're very easy to remove.
I haven't used the whiteline ones but I do have the Turn In Concepts solid aluminum ones. There was no increase in NVH, just a nice increase in information on what's going on with the front tires. This is a highly recommended mod by everyone I've seen that's done it.
Old 06-10-2013, 07:55 AM   #3
DriftEightSix
Pegasus White
Drives: 86
Sweet.
Added to my need to buy list.
Thanks for the feedback/advise1
Old 06-10-2013, 10:33 AM   #4
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
They are soft enough that you don't need to use a press to press them out. I've done a couple cars (mine included), in which you use a 2 jaw clamp. I think it was either a 6" or 8" 2 jaw clamp. It was purchased for cheap at Harbor Freight then returned after I used it. With a lift it's a 30 minute job, without on jack stands it takes about 45-60 minutes as it's a little harder to do when laying upside down. NHV is barely increased. Response from the wheel and feel of the wheel is a little bit crisper. See my build thread for more details I may have forgotten.
stockysnail is offline   Reply With Quote
Whiteline KCA313? wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 04-05-2013 07:12 PM
JRP- New Whiteline Suspension for BRZ/FR-S Stav CANADA 0 10-23-2012 06:38 PM
Whiteline Performance 86drift Brakes, Suspension, Chassis 36 09-15-2012 08:16 PM
