Old 06-08-2013, 10:35 AM   #1
brillo
Drives: 2013 Firestorm FR-S
225/45 on stock wheels
I'm looking to upgrade the tires on the stock wheels and I'm trying to determine if I can go to 225/45 to get a bit more tire with creating a bunch of sidewall flex. While I've searched the topic, I don't feel like I saw a conclusive answer. Car is mostly a daily so I value steering feel over absolute grip. I'm looking at some of the bfg comps as I hear they have a stiff sidewall. I'm open to other suggestions on tires with minimal sidewall flex. Ill do 215/45 if that's the best solution, but there are more tires available in 225/45.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 06-08-2013, 12:01 PM   #2
xwd
Depends on the tire but if you go with a Dunlop ZII, BFG Rival, or Hankook RS3 there isn't a whole lot in lost steering feel.
Old 06-08-2013, 12:05 PM   #3
brillo
Is that due to their stiff sidewalls?
Old 06-08-2013, 12:12 PM   #4
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
You could just go with a high end 215/45. Most of them are a lot wider than the stock tires without the 225 xl load rating penalty. I'm going to try 215/40 ad07s myself. Get some gearing advantage and a much wider contact patch. Nice low weight and super stuff sidewalls. It'll prob be a rough ride and look a little odd though.
industrial is offline   Reply With Quote
Old 06-08-2013, 12:45 PM   #5
brillo
I've compared some of the tires widths on tire rack to the stock michelins. While the overall width is the same for most of the high performance tires I've been considering, the tread width it larger on all the others Michelin PSS, bfg comps, ziis, etc.....
I'm assuming that's better real world width as far as contact patch
Old 06-08-2013, 04:39 PM   #6
wparsons
wparsons's Avatar
There's TONS of good tires available in 215/45/17... every tire I looked at in 225/45/17 and 245/40/17 also came in 215/45/17.
Rivals, Ecsta XS, Z2's, RS3's, PSS, etc are all available in 215/45's.
flickr
Old 06-08-2013, 09:21 PM   #7
brillo
which brands are known for stiffer sidwalls?
Old 06-08-2013, 10:38 PM   #8
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I can comment that the BFGoodrich KDW 2 has very stiff sidewalls.
post_break is offline   Reply With Quote
Old 06-09-2013, 10:33 AM   #9
wparsons
wparsons's Avatar
It's not so much brands, it's specific tire models that are stiffer.
flickr
Old 06-09-2013, 03:35 PM   #10
brillo
I'm looking seriously at the Michelin PSS, BFG sport comp2 and Dunlop ZII. Thoughts on sidewall stiffness?
► Styluz Wheels ► 17x7 18x7.5 5x100 ► In Stock ► Free Shipping FM Wheels Wheels and Tires 2 08-01-2013 05:18 PM
Which 18" wheels will weigh the same or less than the stock wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 05-16-2013 03:07 PM
WTB: Stock Wheels ebgs500e Wheels and Tires 7 04-20-2013 07:38 PM
FS: Stock Wheels+Stock Tires+TPMS sensor Pin Flare Wheels and Tires 1 03-26-2013 11:07 AM
17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? SteveH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-14-2013 10:26 PM
