That guy
Drives: Ultramarine mt FR-S
opinions on this Mod list
I'm not quite sure what sub forum this would go under since it covers a lot of different things. The mods can move it to wherever they deem appropriate.
A good friend of mine came up with a list the other day of the mods he would do if he had a twin. His requirements were, The mods must maintain warranty (no tune, or FI), and allow the car to be a comfortable DD, so NVH must be limited, meanwhile maximizing performance gains. He is a fan of using a single manufacturer for as many grouped parts as possible to allow for the parts to work together harmoniously. I've already asked him why 17x8 instead of 17x9 on the wheel. His response was that he doesn't want any rub, and 17x8 tires are a little more inexpensive. Engine/Drivetrain: - Koyo aluminum racing radiator - Crawford air oil separator - Perrin radiator hoses - Perrin oil cooler kit - Perrin resonated cat-back exhaust - Perrin front pipe w/high flow cat - Perrin overpipe - Perrin silicone inlet hose - Perrin panel air filter - Perrin rear shifter bushing - Whiteline gearbox positive shift bushing Suspension: - Racecomp Engineering yellow springs w/bumstops - Whiteline front strut tower bar - Whiteline front adjustable sway bar 22mm - Whiteline rear adjustable sway bar 16mm - Whiteline rear sway bar braces - Whiteline front/rear endlinks - Whiteline 16mm camber bolts - Whiteline anti lift kit - Whiteline steering rack bushings - Whiteline rear camber adjustment bushings - Whiteline rear positive traction kit - Whiteline differential mount cradle bushing - Perrin front control arm brace Brakes: - Essex/AP sprint 299mm front brake kit - Perrin master cylinder brace - Spiegler stainless front/rear lines Wheels/Tires: - Enkei RPF1 Black 17x8 +45 wheels - Dunlop Direzza ZII 235/40R17 - OEM 17x7 +48 wheels w/ Bridgestone Blizzak LM-60 215/45R17 (winter) Exterior: - Perrin license plate holder - Perrin 2” shorty antenna - STI OEM clear side markers Interior: - ATI 60mm vent pod - DEFI 60mm red racer water temperature gauge 100F-300F - Schroth rallye 3 removable harnesses (track) He also likes Perrin, Whiteline, and Racecomp engineering product. What do you guys think?
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) Last edited by Hawaiian; 05-26-2013 at 11:41 AM. |
Drives: 2013 FR-S, 2016 Miata Club
Whats a 17x8 tire? hee hee
That guy
Yes yes.. wheel.. It's late and I'm drinking.
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
So I take it that he only cares about his engine warranty and not drivetrain warranty? How about keeping the stock tire size instead of 235 to keep weight down? That would drop 2 lbs per corner.
Kuruma Otaku
Looks like a really nice trackable daily driver setup.
Because titanium. |
Looks good!
+1 for smaller tire. Only thing I would add would be a unichip
TRD intake for better throttle response and retain warranty. Plus it dumps off the sound tube and other things from the stock intake. I dunno if the Crawford air/oil separator would be necessary for a non-FI car. Too bad he doesn't want a tune though, that would go a long way. Just flash back to stock.
AutoX-10/10ths every run
I chose 20mm instead of 22mm in the front for the swaybar. Other than that I'd approve.
Koni shocks/inserts...
#10 |
Add horsepower while keeping warranty...
Stickers. |
#11 |
Yeah, NOS stickers! Got NOS?
#12 |
That Guy
Drives: 2013 asphalt FRS MT
The whiteline diff bushings do add a fair amount of NVH, at his power level these might not be worth it.
The Koyo rad seems like it would be overkill to me, but I'm not sure. In keeping with his desire to stay with the same company he might want to take a look at RCE's sway bars as they are designed to work with their spring rates. And either whiteline com-c top hats or group-n strut mounts. These will help reduce flex and movement under load but don't add any discernible NVH. Also, I'd second the tune. He can flash back to stock as required and he wont see nearly the gains even with all the other parts, as he would with the tune. |
#13 |
Drives: 2024 GR86/ 2015 FRS
You would think the radiator and oil cooler might be hard to take the var in for warrenty work?
I would still go 17x9 45 offset with 235's, no rubbing. Get the tune, can always flash back. KW v3's actually ride really nice on the road, more adjustability. Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts |
#14 |
Drives: 2013 Ultramarine Frs
Looks like a well put list for DD as well as track. Although if he worried about price for tires, I would suggest not doing the three exterior mods as they don't improve performance in any way. Might as well put that money towards wider tires for better grip.
| Need opinions! | TakeNoL | Electronics | Audio | NAV | Infotainment | 13 | 01-26-2014 02:14 PM |
| opinions please.... | sillyxmico | BRZ First-Gen (2012+) — General Topics | 15 | 01-18-2013 08:21 PM |
| I need your opinions | WatchmaN | Cosmetic Modification (Interior/Exterior/Lighting) | 25 | 12-12-2012 01:11 PM |
| Opinions wanted on set-up wish list | Hardrock4445 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 11-18-2012 03:21 PM |
| Hello need opinions | ABacic90 | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 06-21-2012 05:23 PM |
