Old 05-23-2013, 04:21 PM   #1
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
CEL P1235 After turbo kit?
Hello FI guys
Im getting a CEL P1235 code which is the fuel pump after a turbo install.
Any of you guys getting this?
Car would stall after like 20 miles and will not run again unless i reset the ecu.
Car will run good again but it comes back.
Let me know what you guys think
86_ZN6 is offline   Reply With Quote
Old 05-23-2013, 04:24 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by 86_ZN6 View Post
Hello FI guys
What FP did you install?? The FP installation is the trickiest part from a mod stand point of this car. I can now do it closed eyes.
Old 05-23-2013, 04:33 PM   #3
crook
crook's Avatar
Drives: storm black GT
I'd pull the pump back out and triple check everything, you can't risk fuel issues
crook is offline   Reply With Quote
Old 05-23-2013, 05:02 PM   #4
jamesm
yes, P1235 is 'fuel pump control out of range'. not good.
Old 05-23-2013, 05:19 PM   #5
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
To speed this up, you should include this information when posting about the issue:
1) What turbokit?
2) What, if any, additional modifications besides the turbokit?
3) Was it installed at a shop, or by yourself?
4) Was the fuel pump modified or replaced with an upgraded unit?
AVOturboworld is offline   Reply With Quote
Old 05-23-2013, 06:22 PM   #6
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
1) What turbokit?
Paul, it is a custom turbo kit by WORKS
Car also have the full works exhaust system
Right now it is still using oem FP. But It was already replaced under the chirping TSB
I know pete will figure it out soon but while im waiting,i just wanted to hear what you guys think about the CEL
Old 05-23-2013, 06:42 PM   #7
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Still oem but will be replacing it with the DW 65C
Old 05-23-2013, 06:53 PM   #8
AVOturboworld
It shouldn't have anything to do with the turbo kit, then. It's much more likely that when it was replaced under TSB, it wasn't done properly.
Turbo kits and super charger kits shouldn't touch the fuel system in any manner, unless there was injectors/fuel pump replaced during the install. So if there is an issue with the fueling, it's a separate (coincidental) issue.
Old 05-23-2013, 08:58 PM   #9
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
There are two fuel pumps, the mechanical direct injection pump which gets replaced under the TSB and the electric port fuel injection pump in the tank. Which pump is this CEL referencing? My guess is that your tuner is doing something weird with the direct injection that the car isn't liking.
Old 05-23-2013, 09:06 PM   #10
Sportsguy83
Drives: Limited BRZ
yeah, like King Tut says, we have two pumps and the code might be because the tune is doing something weird with it, especially since you haven't installed yet an aftermarket in tank pump.
Old 05-23-2013, 11:50 PM   #11
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
not sure which pump really is being referred by the CEL. i will try to replace in tank FP and see if it can remedy the issue.
what FP are you using by the way?
Old 05-24-2013, 01:04 AM   #12
vubaru
Now with Boost!
vubaru's Avatar
Drives: 2013 SWP BRZ Ltd.
This is actually a CEL I haven't seen.
Are you misfiring J? Does it stall in gear or just in neutral? Any other DTCs or symptoms?
What ROM revision are you running if you are on Ecutek? The JA00C ROM revisions have a fuel control issue and you are supposed to use the JA01C. Some more info on your issues could help us diagnose.
vubaru is offline   Reply With Quote
Old 05-24-2013, 01:36 AM   #13
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
long time no see mark.
I will have to ask pete what ROM we are currently running.
the car stalls while running. I took the car home from works and drove through 37. At first i was boosting all the way and everything was fine then after about 30 miles of driving, the car started to jerk and Ultimately it stalls on me while im in low gear.
The car would start up again but it automatically shuts off.
I pulled the battery waited for the ECU to reset then i was able to move again.
Old 05-24-2013, 01:49 AM   #14
vubaru
Now with Boost!
vubaru's Avatar
Stalling while in operation is not fun, but it's interesting that resetting the ECU remedies the issue temporarily. Maybe it's tune related?
But some early stock cars reported the issue: http://www.ft86club.com/forums/showt...t=12428&page=2 The prospect of an OEM issue could exist.
91 MR2 Turbo with KO Racing GT35R Turbo Kit Unleashed Cars for Sale/Trade 2 02-21-2013 05:18 PM
91 MR2 Turbo with KO Racing GT35R for sale/trade for FR-S turbo kit Unleashed Cars for Sale/Trade 8 02-20-2013 06:26 PM
Turbo Tuesday 12/4/2012 (Dynamic Turbo Miami) F3dzo Southeast 46 12-06-2012 01:49 PM
Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? HitTheGas BRZ First-Gen (2012+) — General Topics 12 02-21-2012 01:24 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
