Old 05-18-2013, 09:38 PM   #1
JimmyCrez
Drives: 2012 Toyota GT86
WHEEL SPACERS WITH 1.6" DROP.
Hey guys, i am about to run Eibach Sportline springs. giving me aprox 1.5" drop.
I have 18x8.5 +45 all round, and want to put 10mm spacers on the rear.
Dose anyone see any problems i might come up against ?
My plans are just to enhance looks for the back. and close wheel gap.
Thanks
JimmyCrez is offline   Reply With Quote
Old 05-18-2013, 09:54 PM   #2
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
instead of running spacers run a wider rim in the back, because if you are investing money into rims you should get them perfect and not need to add something to them.
Old 05-18-2013, 10:14 PM   #3
nonicname
Drives: it has 4 wheels and a motor
make sure to get the spacers with stud replacement not the other kind.
then, you'll be perfectly fine.
nonicname is offline   Reply With Quote
Old 05-18-2013, 10:38 PM   #4
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
The reason people do this is so they can have that staggered look while retaining the ability to rotate the tires... Not necessarily because they're being cheap.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 05-18-2013, 10:39 PM   #5
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
This is all well and good unless the OP wants to run a square setup, which would be my guess for the spacers. I for one would rather get a square setup with offsets as close to tolerance as possible then use a small spacer to finish with. I like to be able to rotate my tires front to back to get the most use out of them.
Cade01 is offline   Reply With Quote
Old 05-18-2013, 10:57 PM   #6
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
All a spacer really is... is a different offset wheel. Not literally speaking. If you had an 45mm offset wheel, you can get a 10mm spacer to make it a 35mm offset wheel. That's how wheels are manufactured. They form it with a thick back pad and grind that down to the correct offset. So an Enkei RPF1 with a 35mm offset and a RPF1 with a 45mm offset is the same wheel. It's just that the 35mm offset wheel has a thicker back pad and therefore weighs more. Hope that makes sense. But as others have suggested, if you are just going to use a spacer, be sure to get the extended lugs. Many people suggest ARP studs. Hope this helps.
JimmyMac is offline   Reply With Quote
F/S BNIB H&R 15mm Wheel Spacers jammz Wheels and Tires 1 04-27-2019 08:36 AM
Ichiba and H&R Wheel Spacers on Sale!! Check It Out!! Mike@CZP Wheels and Tires 363 06-17-2018 03:38 AM
Lowered FR-S + Wheel Spacers = ♥ Touge Factory Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 09-13-2015 11:29 PM
Longer wheel studs for those with spacers 000 Racing AUSTRALIA 0 03-20-2013 06:41 AM
H&R Wheel Spacers! vividracing Wheels and Tires 3 06-19-2012 05:11 PM
