Old 05-15-2013, 10:30 AM   #1
Cal3000
Drives: Panda FR-S
Best Boost, A/F, and Oil Temp Gauges
I'm new to FI, so I'm shopping around for some of these gauges. I see cheap ones and I see very expensive one. What are your suggestions for the best gauges to get?
Are they all pretty much the same?
Cal3000 is offline   Reply With Quote
Old 05-15-2013, 10:35 AM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
AEM Falisafe for Boost/AFR
AEM Oil Temp.
The Following 4 Users Say Thank You to Sportsguy83 For This Useful Post:
Cal3000 (05-15-2013), dabocx (07-07-2013), SmsAlSuwaidi (05-15-2013), whitefrs (05-19-2013)
Old 05-15-2013, 10:36 AM   #3
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
People on the forums tend to like the AEM fail safe which comes with both af and boost. I'd personally get that one and then either get the rest aem or look for a proper company ( I personally used defi and they look the best but are very expensive )
Functionality wise cheap and expensive gauges don't differ massively expect the fact a decent normal gauge is going to last longer and wouldn't fail when you need it !
The Following 2 Users Say Thank You to SmsAlSuwaidi For This Useful Post:
Cal3000 (05-15-2013), Sportsguy83 (05-15-2013)
Old 05-15-2013, 11:00 AM   #4
NomoreNA
NomoreNA's Avatar
Drives: Raven FRS
A/F aem failsafe, Boost eBoost2, any other gauges defi
NomoreNA is offline   Reply With Quote
The Following User Says Thank You to NomoreNA For This Useful Post:
Old 05-15-2013, 12:30 PM   #5
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
AEM and Defi are going to get the most love. I have never had issues with Autometer gaues in the past and they give you lots of options as far as the look you want. They are not all the same though. The first thing you need to decide is if you want mechanical or electrical. The AEM Boost gauge is electrical in that you don't have to run a vacuum line up to the back of the gauge it uses a sensor in the engine bay and wires to get the signal to the gauge. The AEM Failsafe boost portion is mechanical and the boost sensor is in the back of the gauge so you have to supply a vacuum line to the back of the gauge.
The Following User Says Thank You to King Tut For This Useful Post:
Old 05-15-2013, 06:08 PM   #6
EZWood
BAMF
EZWood's Avatar
i used to use magellan gauges for my tdi vw. they seemed accurate and reliable. colors wont match though.
The Following User Says Thank You to EZWood For This Useful Post:
Old 05-15-2013, 09:23 PM   #7
Cal3000
Drives: Panda FR-S
Good info. Thanks!
Old 05-16-2013, 09:31 AM   #8
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
The AEM gauges are very popular. Innovate Motorsports has some nice ones too. Defi's are sweet, but pricey and they do not have a wideband. Avoid the cheap Prosport etc brands, they are inaccurate and the senders have a high failure rate. You will just end up buying gauges twice.
The AEM wideband/Boost failsafe is cool, I just wish it was easier to toggle between showing wideband or boost. It is annoying to have to connect with laptop to change it. In my cases we just end up installing a separate boost gauge.
No Limit Motorsport is offline   Reply With Quote
The Following 2 Users Say Thank You to No Limit Motorsport For This Useful Post:
SmsAlSuwaidi (05-16-2013), Sportsguy83 (08-18-2013)
Old 05-16-2013, 09:45 AM   #9
ft_sjo
Drives: GT86
How do you define 'best'? Best accuracy, best looks, best reliability, best for getting forum kudos points?
I personally find analogue gauges considerably easier to read quickly than digital. It also gives you a better idea of transient behaviour.
Stack make a bunch of decent gauges. This would be my choice as they've been in the game a very long time at various levels of motorsport and OEM stuff (e.g. the original Lotus Elise came with a Stack dash).
Old 05-16-2013, 10:14 AM   #10
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
It was my first time going with aem, in the past i used autometer and vdo. I dont regret my choice at all!
Silverdub is offline   Reply With Quote
Old 05-17-2013, 10:47 AM   #11
FeaR-S
Drives: Great White
just saw this posted
Originally Posted by FA20Club.com View Post
Just wanted to share with your our soon to be released Exclusive Gauge that we have been working with P3Cars on developing and testing. After weeks of testing and molding we are nearing completion. The gauge is the most inclusive you can get on the market for this platform. No longer will you have to buy cust single pods or install into areas that cant be viewed very easily in your car. This gauge comes with integration to the OBD2 port so all the major factory sensors can be monitored. Here are some of the solid features of the gauge:
  • READ/CLEAR DIAGNOSTIC CODES
  • PERFORMANCE TIMERS 0-60 60-120 ETC
  • BOOST/VACUUM READINGS
  • MAJOR SENSOR READINGS: COOLANT, AIR TEMPS, ETC
  • X3 ANALOG INPUTS FOR EXTERNAL SENSORS: OIL PRESSURE OR 0-5V
  • REALTIME DATASTREAMING
  • SHIFT LIGHT
  • BOOST WARNING(EXCEEDING MAX BOOST)
We do have the final Beta unit en route for final testing but as it is right now these gauges will be available for sale on July first. We just wanted to keep you guys aware of what we have coming down the pipeline. Retail price will be $380.00 including the vent. Initially we intend to offer a discounted price to kick off sales and will most like be offering a Group Buy when the release date comes closer.
FeaR-S is offline   Reply With Quote
Old 05-17-2013, 11:37 PM   #12
cdemaar
Drives: 2013 Scion FRS
Where did you end up mounting them? Pics?
cdemaar is offline   Reply With Quote
Old 05-17-2013, 11:41 PM   #13
s2d4
s2d4's Avatar
Inaccurate as in how?
Sender? Do you mean the Bosch uego?
Old 05-17-2013, 11:50 PM   #14
No Limit Motorsport
The cheap gauges use cheap quality "sender" units I.E. the boost reading unit, or oil pressure unit. I have never seen a Chinese made wideband but I am sure they exist.
The more expensive brands such as Defi, Stack, AEM, Greddy etc use higher quality, more accurate, more durable components.
FT-86 low temp THERMOSTAT ft86-UAE Engine, Exhaust, Transmission 52 08-30-2016 03:46 PM
Gauges for Turbo, boost controller options? gdrider77 Forced Induction 27 05-13-2013 06:57 PM
A/C Oil/Water temp gauge Exhaust Scion FR-S / Toyota 86 GT86 General Forum 16 02-07-2013 01:19 PM
Engine oil temp now available in Torque App Yruyur Engine, Exhaust, Transmission 8 02-03-2013 10:52 PM
Simple Oil Temp. Gauge Sportsguy83 Cosmetic Modification (Interior/Exterior/Lighting) 4 01-19-2013 08:25 PM
