Old 05-15-2013, 08:12 AM   #1
FRSWiLLY
Drives: 2013 Asphalt
Custom Exhaust - 3" or 2.5" ????
Good day to all! The time has finally come to open up my FRS and create a custom exhaust. I have pretty much everything figured out as far as components goes but i have one question.
Should I go 3" or 2.5"?
Things to consider:
-My set up will be a single exit coming out the driver's side
-I will be starting with the down-pipe all the way back
-I could potentially be boosting sometime in the future
Any opinions are greatly appreciated!
FRSWiLLY is offline   Reply With Quote
Old 05-15-2013, 08:21 AM   #2
CaptainSlow
CaptainSlow's Avatar
2.5 if you're going to stay NA for a while
3 if you're going to go turbo in the next 6 months to a year (otherwise I would just go 2.5 for now, then 3 when you go FI)
2.5 will give you a bit of backpressure, which helps create low-end torque in a NA setup. With FI, you want as free of an exhaust as possible to reduce lag.
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
The Following 3 Users Say Thank You to CaptainSlow For This Useful Post:
FRSWiLLY (05-15-2013), jadewbj (05-15-2013), SirBrass (04-26-2014)
Old 05-15-2013, 08:23 AM   #3
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
Close the thread no more replies needed.
jadewbj is offline   Reply With Quote
The Following User Says Thank You to jadewbj For This Useful Post:
Old 05-15-2013, 08:53 AM   #4
FRSWiLLY
how do i close? moderator help?
The Following User Says Thank You to FRSWiLLY For This Useful Post:
raven1231 (04-26-2014)
Old 05-15-2013, 10:12 AM   #5
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Backpressure is a myth
Old 05-15-2013, 10:31 AM   #6
topazsparrow
Drives: slow
Care to share your source on that?
topazsparrow is offline   Reply With Quote
Old 05-15-2013, 10:51 AM   #7
mrk1
Drives: Sterling BRZ Ltd
2.5 is good for NA street car, some brands have gone with 2.75 but I would think thats better for a NA track car that spends most time in the higher RPM.
Back Pressure is not a myth. The gas velocity also needs to be considered, exhaust travels in the pipes as pulses. Each pulse leaves a low pressure behind it, this in turn draws the next pulse along. This is better known as scavenging.
To small a pipe and its restriction, to large and the effect of the pulse is dissipated. Having said that there is no magical best pipe size mainly because the pulses vary at different RPM. So one exhaust my help low end while another helps higher up. These principles are more obvious when applied to header when each primary is located right at a single exhaust port. An ideally designed header can actually help pull gas out of the chamber, often this ideal design isn't physically possible in the engine bay, but the possibility is there. There is a term of this but it escapes me at the moment. Need to finish my coffee.
Back pressure and scavenging are two different terms but are closely related. People do say with "A larger pipe you will loose back pressure", in some ways its better to say with "Too large of a pipe will loose scavenging".
These principles apply to an entire NA exhaust and FI before the turbine. Turbos disrupt these pulses and in the case of down pipes the concepts of pressure drop can be applied so thats a different story.
Just my .02
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following 2 Users Say Thank You to mrk1 For This Useful Post:
FRSWiLLY (05-15-2013), SirBrass (04-26-2014)
Old 05-15-2013, 03:46 PM   #8
FRSWiLLY
from what ive gathered through opinion (some educated) and my research. A 2.5" exhaust will most likely be a "better" route to go if I am staying N/A for the time being. Lets say i begin to flirt with a header, tune, maybe a throttle body, etc. At what point or HP range will a 2.5" exhaust begin to restrict exhaust flow and/or "scavenging" ?
Again, thank you for your input!
Old 05-15-2013, 04:53 PM   #9
mrk1
I really dont think 2.5 will be a restriction with the normal realm of NA bolt ons. Start getting into FI then stepping it up makes sense.
The Build Thread
raven1231 (04-26-2014), SirBrass (04-26-2014)
Old 04-26-2014, 05:19 AM   #10
pepe
Drives: gt86
Assemble turbo ... if not, it is better to stay at 2.5? "If we put a 3" on a car without turbo is ceirto you lose power at low revs?
perrin has an article in which he says that this is not true, but that you say?
http://blog.perrinperformance.com/3-...ults-and-tune/
pepe is offline   Reply With Quote
Old 04-26-2014, 11:57 AM   #11
xwd
NA I don't think it makes much difference at all really. Some have seen gains going to 3" even NA, but to me the car is too damn loud with a 3" exhaust.
Old 04-26-2014, 12:14 PM   #12
IAmNotTheDriftKing
IAmNotTheDriftKing's Avatar
Drives: I own an FR-S. . . whatelse!
Man up.
4" or GTFO
IAmNotTheDriftKing is offline   Reply With Quote
The Following 2 Users Say Thank You to IAmNotTheDriftKing For This Useful Post:
Flunoir (08-22-2022), SliverBrz (04-29-2014)
Old 04-26-2014, 12:35 PM   #13
ZDan
ZDan's Avatar
Drives: '23 BRZ
2.5 will give you a bit of backpressure, which helps create low-end torque in a NA setup. .
This is not true. Backpressure is bad, hurts torque everywhere. But at low rpm a smaller-diameter exhaust isn't going to create or cause much, so no biggie.
Tuning and scavenging is a different story, but that's more to do with the primaries, not the main exhaust diameter.
3" exhaust won't hurt low-end torque even you if you're running modest power N/A, but it is just unnecessary cost and weight.
Dru670 (06-28-2016)
Old 04-26-2014, 12:36 PM   #14
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Enough of these threads already jesus
The Following 2 Users Say Thank You to BlueDubbinTDI For This Useful Post:
kodyo (04-28-2014), kuhlka (04-26-2014)
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Custom Order Group Buy - Enkei PF01 17" x 9", +35, 5x100 colHolm Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 10-24-2012 10:42 PM
My Wife Found a New "Cat Back" Exhaust Toyota86Fan Other Vehicles & General Automotive Discussions 6 10-15-2012 08:17 PM
