Old 05-13-2013, 01:13 AM   #1
Gregory Gawaran
Drives: 2018 Subaru BRZ tS
Does the gas tank have a metal cap covering the hole?
It does right? I filled up the other day and noticed it was missing but the dealer said it doesn't have one. I do drive my girlfriends MR2 and my 1st gen celicas from time to time so maybe I am mixing information up.
Could anyone verify this for me?
Gregory Gawaran is offline   Reply With Quote
Old 05-13-2013, 01:22 AM   #2
636
636's Avatar
Drives: '23 CWP BRZ
Ehhhh, I don't remember any metal cap.
636 is offline   Reply With Quote
Old 05-13-2013, 01:26 AM   #3
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
No, it never had any. Because race car..
LeeMaster is offline   Reply With Quote
Old 05-13-2013, 01:31 AM   #4
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
you mean like a little spring door on the inside of the tank?
mrlewistan is offline   Reply With Quote
Old 05-13-2013, 01:52 AM   #5
Gregory Gawaran
Should have elaborated more. So you pop the tank, pop the plastic cap, and the spring loaded metal cap where you put the pump into. I know my older cars have it so I don't know if I am just assuming it has one out of association haha.
Old 05-13-2013, 01:53 AM   #6
Gregory Gawaran
I believe your on to what I am talking about.
Old 05-13-2013, 02:00 AM   #7
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
i know my camry has it but i really dont recal ever seeing it on the frs.
edit: so just ran to the garage to check for you. mine dont have the little door. so either i have same issue as you or the frs just dont have those things. im betting on the latter
Old 05-13-2013, 02:06 AM   #8
Gregory Gawaran
Thanks man, I was going crazy like, Does it have one? haha
Old 05-13-2013, 08:00 AM   #9
pascalbrax
pascalbrax's Avatar
Drives: Toyota GT86
My (very) old Toyota Paseo has the metal cap, my european GT86 doesn't.
pascalbrax is offline   Reply With Quote
Old 05-13-2013, 09:19 AM   #10
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
because saves weight
chenshuo is offline   Reply With Quote
Old 05-13-2013, 10:59 AM   #11
strat61caster
strat61caster's Avatar
It's probably located further down the "neck" of the fuel tank. If I remember correctly it HAS to be there by law to prevent fumes from escaping the tank, they figured out in the 80's that the fumes that were being emitted while filling up and letting a gas tank "breath" were incredibly damaging to the environment so they came up with systems to trap them.
Now when you fuel up that big rubber donut creates a seal which channels the fumes in your empty tank to the tank under the gas station as your tank gets filled up, same thing happens when the gas station gets their tanks refilled and then the fumes get transported back to the refinery. Not sure what happens to them if they're re-processed into something or just disposed of in a less damaging way to the environment than venting to the air.
ineedyourdiddly
Last edited by strat61caster; 05-13-2013 at 01:12 PM. Reason: their, they're, there
Old 05-13-2013, 12:58 PM   #12
Freetime
Freetime's Avatar
Drives: Raven Manual FRS
Now when you fuel up that big rubber donut creates a seal which channels the fumes in your empty tank to the tank under the gas station as your tank gets filled up, same thing happens when the gas station gets their tanks refilled and then the fumes get transported back to the refinery. Not sure what happens to them there re-processed into something or just disposed of in a less damaging way to the environment than venting to the air.
WTF. How high are you?
Freetime is offline   Reply With Quote
Old 05-13-2013, 01:11 PM   #13
strat61caster
High enough to have taken classes on engines and gotten a relevant degree to the topic (mechanical engineering).
[ame="http://en.wikipedia.org/wiki/Onboard_refueling_vapor_recovery"]Onboard refueling vapor recovery - Wikipedia, the free encyclopedia[/ame]
http://www.arb.ca.gov/vapor/vapor.htm
http://usatoday30.usatoday.com/money...on-fumes_n.htm
Looks like you live in a state that doesn't require vapor recovery systems (the proper name escaped me for my initial post) so I'm not surprised you are surprised by this information.
ineedyourdiddly
Old 05-13-2013, 01:38 PM   #14
Freetime
Freetime's Avatar
Well thanks for teaching me something new today. You are right, apparently FL doesn't require this as I have never seen it. Feel free to slap me back
Drill a hole in the taillights? dem00n Issues | Warranty | Recalls / TSB 50 01-24-2014 12:58 PM
Covering a large paint chip Panecki17 Cosmetic Modification (Interior/Exterior/Lighting) 0 12-20-2012 02:51 PM
Torque hole discussion jeebus Engine, Exhaust, Transmission 19 08-28-2012 07:51 PM
Mysterious microscopic hole Aznek Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 07-09-2012 08:22 PM
Anyone else considering painting or covering the silver dash panels? Jimbo BRZ First-Gen (2012+) — General Topics 83 04-12-2012 07:32 PM
