Old 05-09-2013, 02:28 PM   #1
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
5W-30 Oil test videos.....
Guys i found a video online comparing BMW 5W-30 Against Castrol 5W-30. At the end of the video you can see that after being boiled at 400 degrees one oil leaves more sediment than the other. My question for the oil gurus is, does this test actually simulate engine oil under extreme heat conditions such as track driving? Also what is the machine used to boil the oil and where can i buy those glass test tubes, if this test is accurate i would love to purchase a kit like this and do my own testing.
If a test like this is accurate i guess the video proves my theory that not oils are created equal even with a simple test.
[ame="http://www.youtube.com/watch?v=g7Tc-YkJRxk"]Castrol EDGE vs BMW 5W30 oils contest - YouTube[/ame]
Found two more videos:
0w-40 test:
[ame="http://www.youtube.com/watch?v=dW227-Bj4wQ&list=UUUNbalgyOO8goWY72Pt-NSA&index=19"]Castrol EDGE vs BMW LL04 0W40 oils contest - YouTube[/ame]
0W-30 test:
[ame="http://www.youtube.com/watch?v=V_B2mjpGuFc&list=UUUNbalgyOO8goWY72Pt-NSA&index=18"]Castrol EDGE vs BMW 0W30 oils contest - YouTube[/ame]
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
Old 05-09-2013, 03:29 PM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
BMW uses Castrol as the oil for its M cars. I wonder how "Original" their oil is.
Old 05-09-2013, 03:43 PM   #3
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Can someone do the same test with Motul and Subaru brand 0w-20 oil?
chenshuo is offline   Reply With Quote
Old 05-09-2013, 03:58 PM   #4
AJ PwR
AJ PwR's Avatar
Drives: R35 R56 CZ4A ZC6
Send a message via ICQ to AJ PwR Send a message via AIM to AJ PwR Send a message via MSN to AJ PwR
MOTUL 300V please ! Not the 8100 !
AJ PwR is offline   Reply With Quote
Old 05-09-2013, 04:01 PM   #5
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Maybe if you got boiling oil in your engine you need to look at something else than the oil you're using lol
Rayme is offline   Reply With Quote
Old 05-09-2013, 05:20 PM   #6
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
Where to start? High temperature stability is just one aspect of oil performance.
Deposits are caused by oxidation to create heavier degradation materials. So what you see left behind could be degraded polymerized lighter materials or just heavier higher boiling materials. So less deposit can mean better oxidation stability or it could be that the one with lesser deposit just boils off at lower temps, so higher oil consumption. There is no discussion about that.
Oils are multifunctional products that have to perform in many different ways. There are and have been lots of very specific demonstrations such as this over the years that focus on one question, but ignore everything else.
To choose an oil based on one demonstration like this would almost be like buying a car based only on the fact that it had 17" wheel as opposed to any other size and ignore all other criteria.
I wouldn't waste your money to acquire the capability to do this. You would be better off discussing your application requirements with an oil manufacturer technical help desk to determine why on an overall basis their recommended product is better for your specific needs. Note, I did not say best, because there are enough different requirements that best amongst different manufacturers would be debateable at best.
smbrm is offline   Reply With Quote
Old 05-09-2013, 09:38 PM   #7
choi0706
Drives: t
+1..
plus your engine wont ever see 400deg, that will be over 700F..
choi0706 is offline   Reply With Quote
Old 05-10-2013, 04:53 PM   #8
bluesubie
Originally Posted by track_warrior View Post
... does this test actually simulate engine oil under extreme heat conditions such as track driving? ...
The easy way to find an oil for the track is to just use a street/track oil like Motul 300V, Red Line, or Amsoil Dominator and be guided by used oil analysis to determine the proper interval. But don't confuse a few uoa's as a tool to compare engine wear or which oil is best. They're better at determining the oil change interval (especially if you get a TBN) and to spot any mechanical problems. There are probably a few 100% street oils that would be fine at the track as well.
I've gotten great feedback from Pennzoil (actually the Global Brand Manager at the time), Red Line, Motul and Mobil1. Actually, the Motul feedback was from the Mid Atlantic distributor, but it's not difficult to contact the Motul USA technical department via telephone.
The more details they have about your specific application the better (typical driving conditions, type of track driving, concerned about being covered under the powertrain warranty or not, etc.).
-Dennis
bluesubie is offline   Reply With Quote
Old 05-12-2013, 01:59 AM   #9
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Yeah, BMW and Castrol are partners. They recommend Castrol Edge anyway so this is kind of weird.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 05-12-2013, 09:22 AM   #10
Blue86
Drives: Sonic Blue 86GT Manual
10W60 for the M cars
Blue86 is offline   Reply With Quote
Old 05-12-2013, 08:27 PM   #11
DJCarbine
Thupercharged
DJCarbine's Avatar
This feels like those plastic gears they have in auto parts stores where you turn a crank and look at how much better one of the oils perform.
Focusing on one aspect, but not telling us anything about all other aspects
P&L Header Dyno and Fitment test-With my Vortech Test Kit Huehuecoyotl Engine, Exhaust, Transmission 118 07-07-2013 10:26 PM
Crash Test Videos!! Finally.... track_warrior BRZ Photos, Videos, Wallpapers, Gallery Forum 23 09-11-2012 06:32 AM
New videos of Frs/86 r1102 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 20 03-04-2012 10:36 PM
New Videos from Carscoop! BobbyBalaz Scion FR-S / Toyota 86 GT86 General Forum 2 11-27-2011 11:39 AM
tC vs the World *videos soon* Dragonitti Other Vehicles & General Automotive Discussions 39 09-15-2011 08:35 PM
