Not trying to be a ****
Drives: BRZ - 6MT - GBS
New from Cusco?
![]() Google translate didn't do a very good job. Looks like something that replaces a part in the dif that can get deformed under heavy stress and cause wear/damage. They posted this on their Facebook page today so I don't think its a repost. Toyota 86 / Subaru BRZ Differential drive pinion Distance color Rear differentiated Publisher And pinion gear in Le The clearer of the ring gear Nsu (backlash) "Type crush" to adjust the I have adopted the color Hatiroc / BRZ. This The suspension and drive system in a manner Tune, powered up An increase in load due to flop Color collapses further, Pull the big trouble May cause. Network Scores of "Difaren Shall drive pinion distance color "is," Sim-like 's Part to change the polynomial ". Strong material that is difficult to deform Color quality, me firmly support the run hard. When you put your hand in the final def change LSD and installed, the same time I want to strongly suggest that the mounting. Improve the reliability of the drive system, to great effect to prevent trouble Required item "run" of 86 & BRZ! And through the propeller shaft from the engine-transmission Power is transmitted to the drive pinion of the differential case in formic I turn the shop. Ring gear that is orthogonal to it (final formic By turning the drive shaft meshes with the dealer), engine The rotational force of the pin is transmitted to the tire. Therefore Doraibupi Engagement condition of the ring gear and anion of (backlash) Adjustment will be very important. Crush type of color Hatiroc / BRZ nor shim adjustable color, I can as well initial adjustment during assembly. (Ime J: left illustration) But to be deformed high load is applied such as sport driving, Position of the drive pinion is a deviation, You become a source of trouble To. On the other hand shim adjustable color of Cusco is difficult to deform a strong District, I will prevent the trouble. (Image: right illustration)
-EvilBeaverFace - My 2013 Subaru BRZ - 6MT - Galaxy Blue Silica
Inland NW 86 Owners Club on Facebook (Spokane, WA/CDA, ID area) FRS/BRZ/GT86 Enthusiasts Facebook Group |
Vtec Jesus
Lol in for more
Drives: waiting on a 2021...
It's a solid spacer that replaces the crushable stock sleeve on the pinion gear. They use them a lot in drag cars and also when you set up different gears in the same housing. It doesn't deform under the the stress of a hard launch(in a drag car) that will sometimes "crush" the stock sleeve a little when the pinion gear pushes against ring gear so hard it pushes the entire pinion gear forward instead of turning the ring gear. Instead of deforming to get the proper preload you use shims behind it to set it up. I can't see a need for it in that sense with these cars, but it also allows you to set up the pinion gear depth and preload easier than crushing the sleeve with a long bar and then checking the drag repeatedly. I run these spacers in the 9 inch differentials I have for my Mustang.
2016 4Runner Tail edition
2020 Camry 2020 RAV4 2013 Chevy 3500 4x4 Duramax 1999 Ford F250 Powerstroke, the tow rig 1969 Mustang, the fast car....(: |
| The Following User Says Thank You to zooki For This Useful Post: | EvilBeaverFace (05-09-2013) |
| FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin | JM Auto Racing | Brakes, Suspension, Chassis | 271 | 03-22-2014 01:17 PM |
| Cusco Engine Mounts and Cusco Rear Diff Brace - Stiffen up your BRZ/FR-S!!! | RallySport Direct | Transmission and Driveline | 10 | 03-12-2013 03:11 PM |
| Cusco Zero 3s on the car | Spaztastik | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 08-02-2012 03:12 AM |
| Cusco Rear Diff Covers!!! Cusco LSD Units! | vividracing | Transmission and Driveline | 0 | 06-18-2012 04:24 PM |
