i'm sorry, what?
Drives: Canada
small oil leak sealant?
Long story short, I have some oil dripping ever so slightly from my oil-pan bolt, I believe the washer was not replaced and hence why.
I got some fresh oil in there and it would be a shame to flush the thing just because of this. The leak is very minor, so I would rather use something to just spray on it until my next oil change. any suggestions?
Drives: '15 STi Ltd
If it's minor and not a big deal... why make it a big deal?
That said, you could clean the area, pop the drain bolt and catch the oil in a clean container for re-use. It's not like it spoils if you drain it. For all my previous subaru products, I would always re-use the crush washer, but I would use a tad of some high temp RTV. Never had a leak. Ironically, I used new crush washer on the FR-S when I changed the oil and it appears that it didn't quite seal. |
Drives: WRB BRZ
This thing is what you need: https://www.flexseal.ca/
i'm sorry, what?
Drives: Canada
infomercial adevertisements, urgh
Drives: asphalt FR-S
it's liquid rubber in a can
Drives: FR-S 6MT
U can unscrew the bolt while the car is cold.. Hold ur finger over it.. Put on washer and screw on.. U won't lose much oil and can add a bit to bring it up to level.. I wouldn't attempt any sealants..
Drives: 13 DGM BRZ Ltd
Flip your car, remove drain bolt, install crush washer, reinstall drain bolt, flip car back onto tires, profit!
| A/T Pan leak | goke186 | Issues | Warranty | Recalls / TSB | 0 | 04-15-2013 10:31 PM |
| Hard body sealant on BRZ | reeves | Southeast | 16 | 03-28-2013 11:33 AM |
| 3M paint sealant VS opti-coat | denverizzles | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 9 | 07-26-2012 12:42 AM |
| Paint sealant for new cars | kurtkarl | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 0 | 06-18-2012 10:12 AM |
