Old 04-30-2013, 04:03 AM   #1
Gums
Drives: SWP BRZ
CAT 3: Rust and Paint Protection Install
BACKGROUND
Thought this may be of interest for owners where they salt roads in winter.
I was keen to keep my BRZ looking good for as long as possible, so in addition to Opticoat I wanted to install a CAT 3.
Family members have had earlier versions of the CAT system installed and have noted it's effect on slowing down oxidation of the paint.
The CAT 3 is designed to greatly slow down oxidation of the metal components, (rust) paint oxidation is an extra.
I have had a cheaper alternative installed on a Toyota 4WD and it has rusted away. Lesson learnt!
Link http://www.roemarketing.com.au/
INSTALL
The instructions are very simple and easy to follow. I chose to install the unit up behind the battery as it would be both cooler and out of the way. Also this was close to the main wiring loom going through the firewall. LHD setup may be different.
So, pulled the battery out and the plastic battery tray
RUST!
Ok, nothing serious, although glad I found it
http://www.ft86club.com/forums/attac...1&d=1367305600
Seems small bits of grit get trapped between the tray and the body. I am speculating that these get ground into the paint by the ever so slight movement of the battery.
http://www.ft86club.com/forums/attac...1&d=1367305645
Sanded it back a bit, applied rust converter, primed and painted with a white paint I had left over from an old Holden.
Then "modded" the underside of the tray to minimise the risk of it happening again.
http://www.ft86club.com/forums/attac...1&d=1367306345
Mounted the CAT3 unit which needs to be screwed into the body so as to ground.
http://www.ft86club.com/forums/attac...1&d=1367306606
Then comes the task of routing the wires to the 2 pads. This was a bit of a pain and I did it over a couple of weeks when I had an hour to spare.
Thanks to the excellent posts on trim removal, I won't duplicate it here.
The most difficult part was threading one of the pad wires through the firewall grommet. The connector was cut off and the wire was eventually pushed through taped to a wooden skewer. Be careful not to skewer any cabling!
Some additional cable was purchased so I could locate one of the pads in the boot.
http://www.ft86club.com/forums/attac...1&d=1367307324
This location wasn't ideal as I had to crush the underside of the foam packing located on top. Once a pad is on you don't want to remove it.
The other pad I located on the strut tower furthest from the battery and ran the cable attached to the main wiring loom running behind the brake booster.
http://www.ft86club.com/forums/attac...1&d=1367307686
Power cable was connected directly to the battery and the earth to the earth on the near strut tower.
Cables were then shortened, soldered, heat shrink'ed and taped to the nearest wiring loom.
CAT3 connector was cable tied to the wiring below the unit.
http://www.ft86club.com/forums/attac...1&d=1367307718
All done.
Light flashes green to say it's working.
Won't drain the battery as unit will switch off if required.
These things are amazing, I have seen a CAT turn a rusty wheel well from brown and powdery to a hard black surface in a few months.
I purchased 2 delivered for $660 AUD (1 for another car)
Hope this helps
Gums is offline   Reply With Quote
Old 04-30-2013, 04:09 AM   #2
Gums
Drives: SWP BRZ
Smile
I'm a bit green when it comes to posting photos!
If one of the mods could fix the photos it would be appreciated.
Exhaust rust prevention paint help LeeMaster Engine, Exhaust, Transmission 12 04-06-2013 12:18 AM
Electronic Rust Protection Fever CANADA 19 02-22-2013 11:40 AM
Factory rust protection in foot well Ben_G CANADA 0 01-20-2013 11:32 AM
Paint Correction, Opti-Coating, Car Wraps, Paint Protection & Tinting - LI Detailers LI Detailers Cleaning and Detailing 1 12-27-2012 04:12 PM
should I opt for the rust/paint protection package from the dealer? kiddo BRZ First-Gen (2012+) — General Topics 9 09-03-2012 11:21 PM
