Old 04-29-2013, 02:18 PM   #1
cmarks20
cmarks20's Avatar
Drives: 2013 Scion FR-S (Raven)
TSW Cadwell Wheels?
So, I'm really digging these TSW Cadwell wheels in gunmetal with mirror cut face and lip. I want to go 18x8 in the front and 18x9.5 in the rear - just in case I do suck it up and go with an FI setup. Thoughts on a Raven FR-S?
cmarks20 is offline   Reply With Quote
Old 04-29-2013, 02:21 PM   #2
ModBargains.com
ModBargains.com's Avatar
TSW doesn't have a 9.5' rear in 5x100 for that particular wheel at least. If you do 'suck it up and do FI' as you say, you may want to take a look at Forgestars too just FYI. 18x8.5 and 18x9.5 F14's in matte black are in stock ready to ship with no 6-9 week wait.
Or another option would be to look at TSW's Rotary forged line up, Interlagos, Panorama, or the Nurburgring.
ModBargains.com is offline   Reply With Quote
Old 04-29-2013, 02:35 PM   #3
cmarks20
cmarks20's Avatar
Good catch, I didn't notice the change to the bolt pattern. I assume I could go with an offset - or I could just hope that 18x8 in the rear is enough to hold traction.
Old 04-29-2013, 02:42 PM   #4
ModBargains.com
Get some really really sticky tires and spend the money there, and you should be ok but depends on how much power you're putting down. Putting a good amount of power down on cheapo tires wont do the trick, you'll need something close to R-compounds to make up for it.
Old 04-29-2013, 02:44 PM   #5
cmarks20
cmarks20's Avatar
It'll be quite some time before I go FI (if at all), so I'll be putting down bolt on power for the time being. That being said, maybe going 18x8 all around - though I love that staggered look.
Old 04-29-2013, 02:48 PM   #6
ModBargains.com
I think staggered looks better as well, but if you love the wheels more than anything else, doesn't look like there's much of a choice. You can always get a staggered set just in another bolt pattern and re-drill the wheels to your bolt pattern to fit if you really really want it!
Old 04-29-2013, 02:54 PM   #7
cmarks20
cmarks20's Avatar
Very true. I'd rather have the wheel just fit without having to modify them or anything. Shame the bolt pattern is off . I'll have to figure something out. Surely someone else is running something similar.
Old 04-29-2013, 05:36 PM   #8
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
If there is room you could always run adapters to make the rears work.
Cade01 is offline   Reply With Quote
Old 04-29-2013, 06:03 PM   #9
ModBargains.com
Typically those adapters are like running 15mm or 20mm spacers, likely that wouldn't happen unless you can find a wheel that has a 60mm offset so you can run around a 40mm or so. I've done the same before on other cars too, that's kind of tough without the perfect offset to start with.
Old 04-29-2013, 08:39 PM   #10
cmarks20
cmarks20's Avatar
I honestly think I can live with the 18x8 all around. Besides, $1500 for the set with Toyo Proxes 4 doesn't seem like a bad deal.
Wheels similar to Technic mesh wheels on bmw's DYOLF26 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 04-26-2017 10:29 AM
FS Momo Tuner Wheels 5x100 W/ KDW Tires (Rare Wheels) kanundrum Wheels and Tires 19 10-11-2013 09:26 AM
Team Dynamics Pro Race 1.3 Wheels (Track wheels) CHEAP!!!! Evasive Motorsports Wheels and Tires 4 07-29-2013 08:46 PM
17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? SteveH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-14-2013 10:26 PM
Wheels, Wheels, Wheels | Island Import Performance IslandImportPerformance Wheels and Tires 4 07-31-2012 10:08 PM
