Drives: 2003 Camry Blue | 2013 FR-S White
18x X +35mm options under stock weight
Anyone have wheel options for this current spec?
Size: 18x7.5 <--> 18x9 Offset: +35mm Weight: X < 20.1 LBS (stock weight) I'm looking for non mesh, but something stylish. 5, 6, or 9 spoke. Budget isn't a big concern, but I would like to spend as little as possible. |
Drives: Whiteout 6MT FR-S; E30 BMW's
Not that it helps with the weight category but 18x9.5 + 35 clears stock suspension so it opens up your selection a little.
Thanks =) too bad no one wants to tell me what those options are =P I'm definitely trying to find something that's light and does not rub.
TSW Nurburgrings would do the trick!
![]() 17x8 - 17.95lbs 18x8 - 18.6lbs ![]() Hope that helps
Whoops! You said non-Mesh, sorry I read that wrong. Interlagos would be a good fit too, similar weights as the Nurburgring:
![]() 17x8 - 17.1lbs 18x8 - 18.85lbs
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Not exact same specs, but how about some of the following:
Enkei PF01, 18x7.5, +38mm offset, 17.6lbs: ![]() Enkei Fujin, 18x8, +40mm offset, 19.0 lbs:
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Another big thing that most people fail to realize, tires almost always weight more then an actual rim.
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus Last edited by OmarGC; 04-27-2013 at 02:16 AM. Reason: Thanks s2d4 |
My FR-S has 5 gears
No realize! Lol been up entirely too long fighting sleep -_-
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#10 |
Thanks all, this gives me a start!! If there is more please post. I've been looking at the new wheels that's called weds something, looks interesting, but expensive.
Sent from my PG86100 using Tapatalk 2 |
#11 |
Drives: 2013 Asphalt FRS
I rock 17x8 45 off Enkei PF01's. 10mm spacer in the rear. This was my car slammed.
![]() They are dipped white now and look way better. Currenlty still have the 235/45/17 hankook v12's on them but looking for go 235/40/17 hankook R3's in the front and 240/40/17 hankook R3's in the rear next summer.
2013 Sion FRS
2014 Subaru WRX 2014 Subaru XV |
#12 |
Drives: BRZ DGM
Phatfux ballzy lol 18x9 +35 ~19lbs
| Stock Exhaust Weight | NYC BRZ | Engine, Exhaust, Transmission | 48 | 07-23-2013 08:13 AM |
| Rays Gramslights 57DR 17x9.0 +35mm Gun Metal Vs Work Emotions 17x7 + 35mm Bronze | jflogerzi | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 02-09-2013 07:09 PM |
| Gmookher wants racing wheels 17x8.5 or 17x9 lowest weight options? VENDORS LOOK HERE | gmookher | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 91 | 01-21-2013 01:40 AM |
| Stock Shift Knob Weight | ngabdala | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 09-05-2012 07:43 PM |
| Stock Wheel Weight | Dionysus | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 04-01-2012 01:46 AM |
