Old 04-25-2013, 02:06 PM   #1
flatline
Factory USB/Aux Connections
I've seen it asked in several threads, without a satisfactory answer, and I'm curious about it myself. Did a quick search and got too many hits to sift through.
How easy is it to install an aftermarket head unit and keep the stock USB/Aux connection that the FR-S has? I know it's possible, but I have no idea if you need to cut and splice wires or if it's a relatively simple procedure.
A followup question would be whether one can also keep the factory mic.
flatline is offline   Reply With Quote
Old 05-03-2013, 12:26 PM   #2
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
USB is easy with a $12 adapter you can buy off eBay Axxess AX-TOYUSB (axtoyusb). AUX connector appears to require some additional modification but some have done it here on these forums. I didn't think it was worth it. I have not seen anyone been successful in reusing the OEM mic. Not sure if it is worth it either since it is so easy to snake an aftermarket mic to the same location as where the OEM mic is located. I would not recommend installing a mic on the steering column as it is too noisy there (from experience compared to installation up top).
mit_peid is offline   Reply With Quote
GT factory amp? derka-derka AUSTRALIA 11 11-06-2022 04:27 PM
Does anybody have any connections to the Pecos RTC? Guff Southwest 5 04-04-2020 01:33 AM
GT86 Headunit connections bonovox DIY (Do-It-Yourself) Guides 4 09-10-2013 06:23 AM
Toyota Touch&Go connections atledreier Electronics | Audio | NAV | Infotainment 1 09-03-2013 02:23 PM
Swap: factory 16s for factory 17s Sydney MZ21 Australia Classifieds 10 07-29-2012 10:46 PM
