Old 04-23-2013, 04:41 AM   #1
SXE10
SXE10's Avatar
Drives: Altezza RS200-Z 6MT
Cusco Diff Pinion Collar/Spacer
I see Cusco Japan have just released a solid replacement for the diff pinion OE collapsible spacer. Could be a worth mod if you're planning on keeping the OE Torsen LSD & it's going to get a regular hard time.
http://www.cusco.co.jp/products/etc-...86_brz_12.html
http://www.cusco.co.jp/products/pdf/...e%20collar.pdf
Originally Posted by Cusco Japan
Genuine part of preload adjustment of drive pinion gear of the rear differential gear of the 86 & BRZ (rear differential drive pinion bearing spacer) by repeating the high-load conditions, such as sports driving gradually deformed to (collapse), finally backlash ( peripheral components and differential gear by tooth contact) of gear would crazy I can lead to damage of.
It is Cusco differential drive pinion color distance has been developed in order to prevent this.
Has adopted the "crush type color" is genuine parts, is the color to change to shimming type this. It is possible to prevent damage to the differential unit without parts deformed even after repeated running hard by a "shimming Type Color." This is the part that you are using for the position which is not visible from the outside, but because it is a part that has taken all of the input from the tire side and the driving force of the engine, it is very important.
It does not pose a problem if only the normal running in the normal state, but from factors such as the following, stress on this component will increase even more in sports driving. <Load factor to color increases>improved traction by wearing · LSD increase of engine power installation of the high grip tire increase of the braking force due to installation of a high-performance brake pads , such as gymkhana and circuit racing, sports driving improvement of the drive transmission response by attachments such as the clutch and strengthening etc ....
SXE10 is offline   Reply With Quote
cusco
Cheap Alternative to Cusco Aluminum Diff Cover and other FRS products! swong46 Engine, Exhaust, Transmission 19 07-27-2014 09:59 PM
Cusco Engine Mounts and Cusco Rear Diff Brace - Stiffen up your BRZ/FR-S!!! RallySport Direct Transmission and Driveline 10 03-12-2013 02:11 PM
Cusco Rear Diff Covers!!! Cusco LSD Units! vividracing Transmission and Driveline 0 06-18-2012 03:24 PM
Cusco Rear Diff. Jewelry Blaaaack-BRZ Engine, Exhaust, Transmission 24 05-12-2012 03:28 PM
