Old 04-17-2013, 07:18 PM   #1
pr086
Drives: fast
My stock shift knob came loose
How do i tighten it back up?
pr086 is offline   Reply With Quote
Old 04-17-2013, 07:18 PM   #2
pr086
Drives: fast
Might sound like a dumb question but ive never had a stick like this one
Old 04-17-2013, 07:20 PM   #3
JohnAyySays
JohnAyySays's Avatar
Drives: Scion FR-S Whiteout
Is this on a manual or automatic? Pretty sure you just line up the whole on the shift knob with the screw on the shift knob and turn it around till it falls in place then just tighten it up
JohnAyySays is offline   Reply With Quote
Old 04-17-2013, 07:23 PM   #4
pr086
Drives: fast
Manual. I was in the middle of shifting and the knob spun, now if i twist it till its tight its not lined up straight
Old 04-17-2013, 07:26 PM   #5
zooki
Drives: waiting on a 2021...
I put a little contact adhesive on the threads(just a little drop) before I screwed mine back on. It will hold the knob from turning, but you'll still be able to give it a good twist and break it loose it you need to. Just screw it down until it lines up and let it cure for a while.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 04-17-2013, 07:34 PM   #6
pr086
Drives: fast
What purpose does the lite silver ring under the knob serve? Id that what locks it in place?
Old 04-17-2013, 07:36 PM   #7
JohnAyySays
Usually I twist it till its tight then move it around till its centere so its a little loose but not loose where it moves around when shifting
The Following User Says Thank You to JohnAyySays For This Useful Post:
eug (04-17-2013)
Old 04-17-2013, 07:49 PM   #8
forzajuve
Drives: Ultramarine 86 - 6MT
Not to come off like a wise-ass. Just turn clockwise till its tight. Good luck
forzajuve is offline   Reply With Quote
Old 04-17-2013, 08:08 PM   #9
pr086
Drives: fast
when i do that till it's tight the numbers don't line up anymore
Old 04-17-2013, 08:43 PM   #10
forzajuve
hmm mine is a little lose as well but I have to give it some effort to twist it. You can always use it as an excuse to get a cool shift knob to replace it
Old 04-17-2013, 08:47 PM   #11
ihaskrayon
The Comedian
Drives: SWP BRZ Limited
If you don't plan on swapping your knob, you could put a little locktite on the threads and alight it straight. That way it wont come loose again and it'll be straight.
ihaskrayon is offline   Reply With Quote
Old 04-17-2013, 09:17 PM   #12
G.I.Choe
Drives: 2013 Scion FRS Argento
Then start screwing it in from a different starting position, ie; make it so the numbers face you upside down and then start screwing in.
G.I.Choe is offline   Reply With Quote
Old 04-17-2013, 10:33 PM   #13
SkitterSkotter
SkitterSkotter's Avatar
Drives: 2013 Scion FR-S (Hot Lava)
This. Probably your best solution. My shift knob moved a bit last summer when the temperatures were quite hot. locktite should set it in place for a while.
SkitterSkotter is offline   Reply With Quote
Old 04-17-2013, 10:54 PM   #14
fistpoint
Drives: Supercharged Golf Cart
Threads don't work like that...
fistpoint is offline   Reply With Quote
The Following 4 Users Say Thank You to fistpoint For This Useful Post:
coastertrav (04-18-2013), eug (04-17-2013), Mandy (04-18-2013), Subie (04-18-2013)
Stock shift knob weight pkny Cosmetic Modification (Interior/Exterior/Lighting) 5 07-30-2015 09:11 PM
MT Stock Shift Knob, Stock Intake w/Snorkel Vicious LED Interior Parts (Incl. Lighting) 1 02-09-2013 03:14 PM
Stock Shift Knob jadewbj Interior Parts (Incl. Lighting) 1 10-26-2012 10:53 AM
MXP Titanium shift knob - in stock No Limit Motorsport Interior Parts (Incl. Lighting) 1 08-06-2012 03:37 PM
