Old 04-17-2013, 03:26 PM   #1
Noob4Life
86 Noob
Drives: Firestorm FR-S
Question for audio enthusiasts
Okay so no flaming me for want I'm wanting to get. My buddy gave me the sub bug again after not having one for awhile. I've got a 2250w planet audio class D mono amp that I've had for awhile and want to put it in the FR-S, I checked out crutchfield and can get a 10" 1000w RMS Alpine Type R and a matching Sound Ordinance ported box for just over 3 bills which made me very happy I've installed audio equipment before so that shouldn't be a problem I was just wondering if there was anything I needed to know before I purchase this setup, I've got the Bespoke audio upgrade in my car. It has sub RCA outputs correct?
I'm not planning on going crazy and running that kinda wattage all the time without an alternator or battery upgrade but I'd like to wire an amplifier controller to the front of the car so I can turn the gain up to show it off every once and awhile. I've looked at some controllers and they seem to be specific to that brands amp. Is there a universal one that'd work for an amp as old as mine? Also should I run straight 0 gauge wiring from the batter and for the ground or would this still be too big?
I'll gladly accept any other useful information that pertains to the setup I want as well.
Thanks guys
Noob4Life is offline   Reply With Quote
Old 04-17-2013, 03:30 PM   #2
Skippman
Skippman's Avatar
Drives: GBS BRZ Limited
Wow, Planet Audio. There's a name I haven't heard in a long time. I remember their aluminum subs.
Skippman is offline   Reply With Quote
Old 04-17-2013, 03:36 PM   #3
Noob4Life
86 Noob
Hah yeah it's pretty old but still kicks like new since I've taken good care of it, at least the last time I had it hooked up which was about 6-7 years ago. Paid 360 bucks for it then, but it's been kept safely inside in my room and not touched much so I'm assuming it'll work like new.
Old 04-17-2013, 10:29 PM   #4
cmarks20
cmarks20's Avatar
Drives: 2013 Scion FR-S (Raven)
Audio Control sells a few line level units that have a remote gain control. I‘m using their LC2i unit for my current setup. Theres a pic on the audio list.
cmarks20 is offline   Reply With Quote
Old 04-17-2013, 11:22 PM   #5
cruzinbill
Drives: Argento 6spd FR-S
Your amp prolly puts out around 8-900 watts tops, so I wouldn't be concerned with the car electrical unless you plan to run over 2k watts rms.
Yes bespoke has RCA out, you also have sub level control through it. If that isn't enough, just pick this up they work good. http://www.sonicelectronix.com/item_...xess-AALC.html
As for the wire size, a real 4g wire would be fine, If you want to play it safe for anything in the future tho sure, go 0g.
cruzinbill is offline   Reply With Quote
The Following User Says Thank You to cruzinbill For This Useful Post:
Noob4Life (04-17-2013)
Old 04-17-2013, 11:35 PM   #6
Noob4Life
86 Noob
Thanks man! Ill grab a good quality 4g kit then as I wont need anything bigger than this setup. So your saying 8-900 watts rms is what this amp would probably put out? Not too bad, would this be with the gain turn most of the way up?
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Old 04-18-2013, 09:32 AM   #7
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
Crutchfield has stuff for the BRZ? Everytime i log on to check they have not updated anything for vehicle specific.
Marcoscrdo is offline   Reply With Quote
Old 04-18-2013, 09:48 AM   #8
Noob4Life
86 Noob
Im not gonna get a vehicle specific enclosure, wanted one but im getting impatient anthe ones out now seem to be shallow mount subs which wont handle the power im wanting
I dont need the trunk space right now anyways lol
FRS/BRZ/GT86 Enthusiasts Group. NickFRS Northwest 15 06-30-2014 10:57 PM
FR-S/BRZ enthusiasts North of the GTA 13 FR-S Veteran CANADA 16 10-01-2013 11:48 PM
FR-S Audio Build - SQ (Illusion Audio/Mosconi) DekaMori Electronics | Audio | NAV | Infotainment 28 04-17-2013 04:34 AM
'Noobish' questions as I look to upgrade my car audio audio. DkY in Vcr Electronics | Audio | NAV | Infotainment 0 09-22-2012 09:45 PM
BRZ Audio Question poudre Electronics | Audio | NAV | Infotainment 4 07-11-2012 08:48 AM
