Old 04-17-2013, 12:16 AM   #1
VesperLynn
VesperLynn's Avatar
Drives: Subaru BRZ
Alright, lets help a twin out
I'm looking for a set of 17's for a track setup. Just need to figure out what offset I want to go with. Ideally I want to do the same width all the way around with a 9.5.
I do have the Rockeybunny kit fitted so that is a factor. Current wheel setup is Forgestar F14's all around, -3 offset in the front, 6 in the rear (if I remember correctly, it could be backwards, but the numbers and the negative, will get the definitive answer tomorrow).
VesperLynn is offline   Reply With Quote
Old 04-26-2013, 12:45 PM   #2
ModBargains.com
ModBargains.com's Avatar
Why not another set of Forgestars? Just another model from Forgestar maybe. They don't make 17's but you could go with 18" CF5's for example which have big clearance on the inside just in case you need to run a BBK on it too. A spacer would be required, but most the wheels you'll require with the offset you need, will need a spacer.
ModBargains.com is offline   Reply With Quote
Old 04-27-2013, 05:21 PM   #3
jflogerzi
jflogerzi's Avatar
IMO if you are looking for a dedicated track set, function over looks. I would find the lightest wheel that still have decent durability thats in-expensive(think replas or knock-offs) that will allow for the a good tire as well.
Alright to use 5-6 old coolant? Hanakuso Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-11-2013 08:47 PM
Alright to tint windows in winter (cold)? Chinadian CANADA 19 03-21-2013 02:31 PM
Alright to install clear bra in winter (cold)? chenshuo CANADA 7 01-28-2013 05:46 PM
I hope it's gonna be alright... K2wings Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 08-31-2012 03:57 PM
Saw a car, fell in love, deposit down.... Did I do alright?? Chewie4299 Scion FR-S / Toyota 86 GT86 General Forum 13 06-21-2012 11:52 PM
