Old 04-16-2013, 09:03 AM   #1
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Best street coilover
Hi,
I plan to install a coilover set soon, what is the best coilover i can take for street use? Maybe some futur track days also.
My friend run on BC with a 350z and it feel confortable, what is your suggestions?
I look for Tein maybe : http://www.jscspeed.com/catalog/Scio...cion_FR_S.html
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 04-16-2013, 10:49 AM   #2
Mgivens
Drives: Fr-s MT Ultramarine
the BEST...in my opinion it is the Ohlins road and track... but at $3500 it aint cheap!
good luck, if i had the money i would get them in a second...
if i was a t a lower budget i would try the AST set
of, even lower budget get the Koni inserts with RCE springs!
Mgivens is offline   Reply With Quote
Old 04-16-2013, 10:51 AM   #3
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
he said street
what are you gonna do with ohlins on the street, LOL
Huehuecoyotl is offline   Reply With Quote
Old 04-16-2013, 10:56 AM   #4
Mikepage
Mikepage's Avatar
Yeah i have already read a lot on the RCE springs but i plan to use my car during winter and maybe with the coilover, i can adjust the height before the winter season begin.
o= FR-S =o
Old 04-16-2013, 10:57 AM   #5
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
kw v3, stainless steel which won't rust or seize as easily in Canadian salted winter
shu5892001 is offline   Reply With Quote
Old 04-16-2013, 10:59 AM   #6
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Stock.
IMO.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
CSG David (04-16-2013)
Old 04-16-2013, 10:59 AM   #7
Mgivens
Originally Posted by Huehuecoyotl View Post
he said street
Ohlins is overkill, but they seem to have made it for the street...their discription "The focus has been clearn from the very beginning - superior road handling without sacrificing comfort in your day-to-day transports."
Old 04-16-2013, 11:05 AM   #8
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
he said street
If you want higher spring rates but OEM ride quality then high end dampers are the answer. I've been in very highly sprung cars running high end Showa dampers, Penske, etc that feel as comfortable as stock, just more controlled.
Try that with BC dampers and you'll get that "It's a performance suspension" ride...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
autobrz (09-13-2013), CSG Mike (04-16-2013)
Old 04-16-2013, 11:09 AM   #9
Huehuecoyotl
GC makes a affordable height adjustable perch option that may be for you and still ride better than a cheapy set of coilovers
http://www.ground-control-store.com/...ion.php?II=923
.look into it.
Old 04-16-2013, 11:09 AM   #10
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
How low do you seriously plan on going?
Grimlock is offline   Reply With Quote
Old 04-16-2013, 11:28 AM   #11
speed6sam
Drives: SWP BRZ Limited 6 Spd
Have you ever actually taken a car with properly setup BC Racing coilovers for a ride?
speed6sam is offline   Reply With Quote
Old 04-16-2013, 11:30 AM   #12
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I've been in 3 or 4 cars with BC coilovers. I can't say whether or not they've been properly setup (I didn't mess with them at all).
Have you ever been in a 1,200lb spring rate car on high end dampers that rides like stock?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
speed6sam (04-16-2013)
Old 04-16-2013, 11:45 AM   #13
speed6sam
I honestly can't say Ive been in a car with 20-22k spring rates, The most I have ridden in was 16k front and 14k rear which translates to 899lbs front and 787lbs rear.
I am sure that was very impressive and at the same time very expensive. I run 564lb springs front and rear in my personal car and thats plenty comfortable for myself personally and performs well from the little testing I have been able to do.
I do have to say however that if a guy doesn't set their suspension up properly no matter what kit they have, it'll ride horribly. It seems to me that a lot of the people that buy BC's usually throw them on and adjust them incorrectly then post negative reviews on the forums.
Old 04-16-2013, 11:52 AM   #14
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'd agree with that across the board.. not just BCs..
Although I haven't seen that many negative reviews. The high end damper guys don't respect the whole 'anodize it another color and put a different sticker on it' sales methodology, that's most of the negative comments I see about them.
In the end, they simply can't compete with 2, 3, 4 way dampers, regressive valving, etc when it comes to controlling higher spring rates over varied shock velocities.
Having said that, if the street was my only concern, I'd still say stock lol
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Huehuecoyotl (04-16-2013), speed6sam (04-16-2013)
Cusco Street Spec A Coilover Kit Scion FR-S Subaru BR-Z No Upper Mount FRS-HHH Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 03-31-2016 07:17 AM
Megan Racing Street Series Coilover Kit DeeJayMajesty Brakes, Suspension, Chassis 4 03-22-2013 04:59 PM
Tein Street Basis coilover, Koni struts and shocks JoeBoxer Brakes, Suspension, Chassis 6 12-25-2012 09:43 AM
