Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > New England
New England MA, ME, NH, RI, VT
Old 04-03-2013, 10:02 PM   #1
rainmonkey
Drives: BRZ - Dark Grey
CitySide - First Service?
So I'm going to be having my first service done at CitySide Subaru. I currently have the following:
1. Perrin ECU tune
2. Perrin Catback
3. Perrin Drop-in Filter
4. Perrin Lightweight Pulley
5. Kartboy Short Shifter
I've heard from friends, from @Kaizen Tuning, and from the dealer salesman himself that CitySide is pretty mod friendly. However, do you guys think I should reflash the ECU to stock and swap the filter back out to the OEM before servicing?
Thanks!
rainmonkey is offline   Reply With Quote
Old 04-03-2013, 11:45 PM   #2
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
1. Perrin ECU tune
2. Perrin Catback
Thanks!
I had pretty much the same mods when I went in for my fuel pump and GPS TSB and Cityside didn't make a big deal about it...the only mods I didn't have were the CAI at the time. They didn't give me any trouble for anything when I was there, you're just going in for a regular service so I wouldn't worry about it at all.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 04-03-2013, 11:52 PM   #3
rainmonkey
Even the flash? I know Kaizen did your tune, so not sure how that worked.
Speaking of TSB's did they work? and did you have to prove it to them that you had the issues? The chirp is easy enough to induce, but the GPS...
Old 04-03-2013, 11:59 PM   #4
Sony
Sony's Avatar
Yes, I had the tune at the time. Both TSB's have done their jobs so far and neither problem has returned. *crosses fingers* All you have to do is tell them that YES you have the problem, then they will go out to you car and see if it is true, I don't kow what their procedure is to do this but they confirmed both TSB's and ordered the parts and I had both problems fixed within 2 weeks. No issues with mods, it did take them 2 days to replace the fuel pump for some reason but everything seems to be working properly so it's all good.
Old 04-04-2013, 07:47 AM   #5
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
Not sure about these cars but most today will show a residual footprint (evidence) of the aftermarket tune even if you reflashed back to stock. Usually the first thing the tech sees when he plugs in. 'Big brother' may be watching your ECU! But if the dealer is mod-friendly, shouldn't be an issue, especially if it has no bearing on the work to be done.
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
Old 04-04-2013, 08:17 AM   #6
sklimo
Speaking of mod friendly shops, know of any in CT?
Old 04-05-2013, 08:45 AM   #7
Clembo
Clembo's Avatar
My Ford dealer is great with Mustangs and Shelbys. But for Scions / Subarus, none that I know of. I assume my own Toyota dealer might be a bit forgiving if only because I have been buying there for years and the parts manager is president of my Mustang club. But I doubt I'd push it even there.
Ask various Service Managers how they feel about mods and how far they would be willing to go. Some will ignore tunes, exhausts, intakes, etc., but not turbos / superchargers. - that's what I did at my Ford dealer and found the Service Manager has several highly modified cars and trucks himself. He said he'd cover anything that happened 'within reason'. There's always a caveat...
Don't forget you have some recourse under the Magnuson-Moss Warranty Act. But many dealers will argue that the act doesn't apply to your 'problem' (even if it clearly does) and unless you have the time and energy to fight it, you'll be up the proverbial creek.
Old 04-05-2013, 11:05 AM   #8
Sony
Sony's Avatar
Also check out www.dealerrater.com for ratings of dealers in your area, thats how I found CitySide
Old 04-06-2013, 05:42 PM   #9
rainmonkey
@Sony got it done today, they're ordering a fuel pump and a replacement antenna for the GPS thing (i thought it was a software update - but apparently not...)
No problems with the mods/tune.
Service fees in the UAE RevoG ASIA 65 12-24-2013 10:33 PM
Which dealership for first service? randomweather CANADA 1 12-23-2012 12:57 PM
1st service brz7400 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 09-16-2012 12:37 AM
Free Service DHarry CANADA 2 09-14-2012 08:22 PM
BRZs available at Cityside Subaru, Belmont, MA NRGBalanced New England 2 07-06-2012 12:20 PM
