Old 04-02-2013, 12:14 AM   #1
Sev
Desert Nomad
Drives: 2013 BRZ Limited 6MT WRB
Hankook RS3s = too much body roll. Suggestions?
Tracked my BRZ yesterday using Hankook RS3s 225/45/17; everything else stock.
The RS3s gave me a lot more grip than stock tires but introduced a lot of body roll that I wasn't used to getting and really threw me off. Felt like I was driving a heavier car.
My buddy really eliminated his Camero's body roll with sway bars but what worked for his car won't necessarily go as far on ours.
What's the best thing I can do to reduce body roll for our car? Thanks.
Sev is offline   Reply With Quote
Old 04-02-2013, 12:16 AM   #2
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Lower COG, slightly higher spring rates help a ton.
If you want to go about it on the frugle route, H&R & Eibach have some quality springs for cheap. Also, sways will help like you stated.
edit: What class are you running in?
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 04-02-2013, 12:23 AM   #3
blkwrxwag
Drives: DS FRS
Strano front bar and Eibach Pro kit, plus camber bolts.
blkwrxwag is offline   Reply With Quote
Old 04-02-2013, 01:08 AM   #4
CSG David
CSG David's Avatar
Body roll can be controlled with sway bars and stiffer springs. Changing these parts does not necessarily change performance of the car despite the change in feel. Where did you run your car at?
Old 04-02-2013, 02:28 AM   #5
Sev
Desert Nomad
The only modification I've done is RS3s 225/45/17 on Enkei RPF1s. There isn't anything stopping me from further modification other than $ and complexity/skill. I'm new to tracking (TT but no competitions) and plan to do more as often as I can.
Does that help?
I ran at Streets of Willow Springs yesterday. I remember seeing the CSG BRZ there. Maybe I can get a ride one of these times?
I'm positive that the biggest problem lies between steering wheel and seat so best bang for my buck would be a drivers school but I'd also like to get rid of the heavy body roll I experienced or is that something I'd be better off learning to deal with unless I'm willing to do a lot of modifications? Not as much fun as the go-cart-like experience I got from running completely stock.
As for sways, I've read that other people here are only using front sway bars. (Robispec for example) Why is that?
Old 04-02-2013, 02:55 AM   #6
D1cker
Drives: B9 S4/ND2
just drive a bit more for now, a car that rolls over is more forgiving and easier to learn with.
What was your best time at streets yesterday?
D1cker is offline   Reply With Quote
Old 04-02-2013, 08:12 AM   #7
Sev
Desert Nomad
Thanks for the advice.
Best time was 1:35 (CW). Have trouble with turn 2 & 3 and with trying to double apex the bowl. Also I tend to coast before breaking rather than staying on the gas and breaking harder.
Old 04-02-2013, 11:15 AM   #8
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Because of the way the stock rear differential works. If you lift one of the rear wheels you basically lose all power until that wheel gets traction again. Assuming traction control is off.
Ranatsu is offline   Reply With Quote
Old 04-02-2013, 11:57 AM   #9
Does that help?
All you need to do is ask
Robispec's suspension is NOTHING like stock, so that's an apples to oranges comparison.
We're still on stock sways. How's this for roll? This is also on 225/45/17 RS3 on RPF1. Car is only lowered 1.4 inches.
Old 04-02-2013, 11:59 AM   #10
True, but I don't think I've seen anyone actually lift a rear wheel on street tires... please correct me if it's a common occurance that I just haven't observed at SoCal tracks.
Old 04-02-2013, 12:03 PM   #11
Ranatsu
Cone basher
I haven't in this car. On my STi with the stock springs and Cobb sway bars I could pick up the inside tire everyday driving to work, but thats a completely different animal.
Old 04-02-2013, 12:16 PM   #12
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
youre on stock coils? and sways? Go to a minimum of an RCE yellow coil and a minimum of a strano sways and report back. I put my rcomps on the wifes car and felt the same way, too much traction
Dialing back to the direzzaV1 feels fine with oe coils and sways, fwiw
she smiling now!
Huehuecoyotl is offline   Reply With Quote
Old 04-02-2013, 12:30 PM   #13
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
Are the people here who have done tires and stiffened the suspension still okay with the stock bushings? I would think those would be the next weak link... but am curious if people are noticing them.
blu_ is offline   Reply With Quote
Old 04-02-2013, 12:50 PM   #14
We're still on stock bushings
Wheel Directory: Rota Grid 17x9.0 +42 BlaineWasHere Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 81 06-26-2015 08:12 PM
Has anyone actually seen any of the Cusco roll bar / roll cages installed? xenocharger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 06-03-2013 06:54 PM
FS NJ: hankook rs3 255/35/18 VSGTS14 Wheels and Tires 2 03-04-2013 03:02 PM
How to make the body kit sit flush against the body? JasonCDC Cosmetic Modification (Interior/Exterior/Lighting) 12 01-10-2013 04:07 PM
Roll stiffness: Springs vs anti-roll bars? Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 07-24-2012 05:44 PM
