Old 04-01-2013, 09:05 PM   #1
ThatManAnt
Drives: Whiteout FR-S 6spd
Oil
Does Eneos, Amsoil, redline or motul oil really make THAT big of a difference for the price? I just DD my car, no tracking... spirited driving on backroads every now and then. Is it really necessary?
ThatManAnt is offline   Reply With Quote
Old 04-01-2013, 10:02 PM   #2
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
why not just use factory?
Huehuecoyotl is offline   Reply With Quote
Old 04-01-2013, 10:10 PM   #3
YourFearlessLeader
Team ScioNRG President
YourFearlessLeader's Avatar
Drives: 2017 WRB BRZ
yes it does.
does eating healthy every day make a difference even if you aren't a professional athlete?
2017 Subaru WRB Limited BRZ w/ PP
YourFearlessLeader is offline   Reply With Quote
Old 04-01-2013, 10:29 PM   #4
suaveflooder
Originally Posted by YourFearlessLeader View Post
yes it does.
Eh, I get what you're trying to say, but on a car that is a DD with a decent drive time (oil allowed to heat up), he's probably not going to see much of a difference. I like your analogy more with fuel
OP, you are driving with "extreme conditions," I would highly suggest going with a better oil. An every day DD with correct oil changes probably won't see much of a difference.
I'll just be running toyota oil until I start autoxing it
suaveflooder is offline   Reply With Quote
Old 04-01-2013, 10:30 PM   #5
reeves
Nothing but a wholesome 100% Amsoil 0W-20 diet for my brz
reeves is offline   Reply With Quote
Old 04-02-2013, 03:11 AM   #6
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Dude has a point. Factory fill is damn good stuff.
Considering my experiences at the dealer, I'd recommend buying it and doing the oil change yourself.
PRO86 | WTCC | STL
Old 04-02-2013, 07:28 AM   #7
SloS13
Drives: 2013 FR-S whiteout
+1
SloS13 is offline   Reply With Quote
Old 04-02-2013, 09:50 AM   #8
BAS
Drives: Snow White
Eneos Sustina 0w20.
TRD Exhaust/Cold Air Intake/High Pressure Radiator Cap (1.3 bar/18.5 psi)/Door Stabilizer, Cusco Front/Rear Type OS Strut Tower Brace/Power Engine Member Brace/Rear Member Brace, 215/45ZR17 PSS, Perrin Master Cylinder Brace/Shorty Antenna/Front Tow Hook License Plate Mount, TWM M1 Abrams White Pearl Shift Knob, SilverStar Ultra H11/9005, OEM Auto Dimming/Home Link Rearview Mirror, Full LED's with Switchbacks and JDM Clear Sidemarkers
BAS is offline   Reply With Quote
Old 04-02-2013, 10:08 AM   #9
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
I will continue to use Subaru's oil (free oil changes) until the third oil change, when all the factory particulates and cocktail fluids are removed. Then i will change over to Eneos.
Old 04-02-2013, 12:37 PM   #10
Huehuecoyotl
OP said DD duty oil
Old 04-02-2013, 02:06 PM   #11
Hanakuso
Not sure if you're talking about Subaru or Toyota, but i've been reading on the bob oil forum and many say the Toyota 0W-20 is one of there favorites.
Hanakuso is offline   Reply With Quote
Old 04-02-2013, 02:59 PM   #12
rice_classic
So then the answer is "yes".
Because the Subaru 0w-20 is quite good.
PRO86 | WTCC | STL
Old 04-03-2013, 08:27 AM   #13
ThatManAnt
Yeahhhh I don't have sustina money lol. But I think my dealership uses penzoil, at least when I got my car I asked the service department and they said they had penzoil. Idk if they rotate oils but if they don't I'd be getting penzoil instead of OEM Toyota for my free oil changes
Old 04-04-2013, 11:17 AM   #14
bluesubie
Yeah, who want the factory fill in there too long will the higher levels of anti-wear additives for a better break in.
You can't go wrong with either oil. IMO, Pennzoil is one of the better off the shelf oils that you can buy.
The NOACK volatility (% of evaporation) of Pennzoil Platinum 0W-20 is on par with Red Line 0W-20 (if the test methods are the same). 8.9% with PP and 9.0% with RL. http://www.epc.shell.com/Docs/GPCDOC...1212050515.pdf
http://www.redlineoil.com/product.aspx?pid=124&pcid=21
Many GF5 oils are closer to the API's NOACK limit of 15%.
http://www.infineum.com/Documents/AP...ons%202010.pdf
The lower the NOACK the better.
-Dennis
bluesubie is offline   Reply With Quote
The Following User Says Thank You to bluesubie For This Useful Post:
suaveflooder (04-04-2013)
